0 Replies Latest reply on Feb 23, 2010 7:08 AM by Carol L. Frampton
    [svn:fx-4.x] 14355: Fix bug in drawSeparators().
    Carol L. Frampton Level 2
      Revision: 14355
      Revision: 14355
      Author:   cframpto@adobe.com
      Date:     2010-02-23 07:07:41 -0800 (Tue, 23 Feb 2010)
      Log Message:
      Fix bug in drawSeparators().  Spark skins don't measure if there is an explicitWidth and an explicitHeight so measuredWidth is 0.  For Spark skins needs to use getExplicitOrMeasuredWidth() instead.
      Fix bug in skin which may have been to compensate for the above bug.  The net should be no visible change to the header separator but custom spark skins should measure correctly now.
      QE notes:
      Doc notes: None
      Bugs: SDK-25441
      Reviewed By: Alex
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25441
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataG ridHeader.as
          flex/sdk/branches/4.x/frameworks/projects/sparkskins/src/mx/skins/spark/DataGridHeaderSep aratorSkin.mxml
