10 Replies Latest reply on Feb 24, 2010 10:44 PM by venkatsyss
    Regarding Check and ID
    venkatsyss Level 1
      hi,
      My question how i concatenate one or more ids in http service when checkbox are selected in the dataGrid.
      The following Code shows the datagrid and the database Query.
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"  layout="absolute" creationComplete="userRequest.send()">
      <mx:HTTPService id="userRequest" method="POST" useProxy="false" url="check.php" result="Display(event)">
           <mx:request xmlns="">
               <memid>{uRequest.selectedItem.userid}</memid>
           </mx:request>
      </mx:HTTPService>
      <mx:Script>
           <![CDATA[
               import mx.events.ListEvent;
               import mx.rpc.events.ResultEvent;
               import mx.collections.ArrayCollection;
               import mx.controls.Alert;
               import mx.controls.DataGrid;
               [Bindable]private var arr:ArrayCollection;
               private function Display(event:ResultEvent):void{
                   arr=event.result.users.user;
               private function handleSelect(value:Boolean):void
                       userRequest.lastResult.users.user.source.forEach(
                           function callback(item:*, index:int,
      array:Array):void
                               item.sel = value;
                       userRequest.lastResult.users.user.refresh();
                   private function Update():void{
                       userRequest.send();
      </mx:Script>
      <mx:DataGrid dataProvider="{arr}" id="uRequest" >
      <mx:columns>
      <mx:DataGridColumn>
           <mx:itemRenderer>
           <mx:Component>
               <mx:CheckBox selected="{data.sel}">
              </mx:CheckBox>
           </mx:Component>
      </mx:itemRenderer>
          </mx:DataGridColumn>
          <mx:DataGridColumn headerText="Sl.No" dataField="userid"></
      mx:DataGridColumn>
               <mx:DataGridColumn dataField="username">
               <mx:DataGridColumn dataField="useremail">
               <mx:DataGridColumn dataField="userstate">
          </mx:columns>
      </mx:DataGrid>
      <mx:Button label="CheckAll" click="handleSelect(true)">
      </mx:Button>
      <mx:Button label="Update" click="Update()">
      </mx:Button>
      </mx:Application>
      //My Database Query
      if($_POST['memid']!=''){
              $id=implode(',',$_POST['memid']);
              $ids=substr($id,0,20);
              $ans="update tbl_member set member_lname='example' where member_id
      in($ids)";
               $res=mysql_query($ans);
              $answer="select * from tbl_member";
               $result=mysql_query($answer);
              print "<users>";
              while($row=mysql_fetch_object($result)){
              print "<user>
               <userid>".$row->member_id."</userid>
               <username>".$row->member_fname."</username>
               <useremail>".$row->member_lname."</useremail>
               <userstate>".$row->member_state."</userstate>
               </user>";
              print"</users>";
      Please provide me the solution to solve the problem.
      Thanks and Regards,
      venkat.R
        • 1. Re: Regarding Check and ID
          archemedia Level 4
          You could do something like:
          private function doIt():void
               var a:Array = new Array();
               for each (var item:Object in myDataProvider)
                    if (item.sel)
                         a.push(item.id);
               var s:String = a.toString();
               //now, send s to your service
          Does this help?
          Dany
          • 2. Re: Regarding Check and ID
            venkatsyss Level 1
            hi,
            Thanks for your reply.But i could not able to get the answer.
            The Error shows "Access of undefined property mydataProvider".
            If i have  used  dataprovider id "urequest" the answer will not display it.
            Thanks and Regards,
            venkat.R
            • 3. Re: Regarding Check and ID
              archemedia Level 4
                        if (item.sel)
                             a.push(item.id);
              It's just an example. myDataProvider should be replaced with the name of your ArrayCollection. This collection holds all your object. Suppose your ArrayCollection holds object like this:
              var myDataProvider:ArrayCollection = new ArrayCollection([{id: 1, sel: true}, {id:2, sel: false}]);
              In your case, the property names id and sel might be diffrent!
              Dany
              • 4. Re: Regarding Check and ID
                venkatsyss Level 1
                hi,
                Thanks for your kind reply.i get the result successfully but i could not able to send the value to the service.
                The followind code shows the http service.
                     for each (var item:Object in arr)
                          if (item.sel)
                              selArr.push(item.userid);
                                 var s:String = selArr.toString();
                                userRequest.send();
                But i could not able to get the request.Please find me the solutions to solve the problem.
                Thanks and Regards,
                venkat.R
                • 5. Re: Regarding Check and ID
                  venkatsyss Level 1
                  hi,
                  Successfully i send the vardiable to the service and update the database.
                  Thanks a lot for you given a  support  to me.
                  Once again thanks.
                  Thanks and Regards,
                  venkat.R
                  • 6. Re: Regarding Check and ID
                    archemedia Level 4
                    Great! Good luck
                    d
                    • 7. Re: Regarding Check and ID
                      venkatsyss Level 1
                      hi,
                      I have another question regarding checkbox.
                      how i have to check, in  foreach or for loop  if i have selected manually in the  checkbox in itemrender in the datagrid.
                      Thanks and Regards,
                      venkat.R
                      • 8. Re: Regarding Check and ID
                        venkatsyss Level 1
                        hi,
                        Thanks for your  kind reply and  support for me.....
                        Thanks and Regards,
                        venkat.R
                        • 9. Re: Regarding Check and ID
                          archemedia Level 4
                          Maybe this post will put you on your path. If not, just post a new topic.
                          http://forums.adobe.com/thread/583996?tstart=0
                          Dany
                          Message was edited by: archemedia: corrected the link to the post
                          • 10. Re: Regarding Check and ID
                            venkatsyss Level 1
                            hi,
                            I have posted a new topic in the forum.
                            The above path is shows the url:
                            http://forums.adobe.com/thread/584714
                            Thanks and Regards,
                            venkat.R
