7 Replies Latest reply on Apr 5, 2011 8:20 AM by covenant2
    Separate Template Created Pages Won't Link
    covenant2 Level 1
      I'm working on creating a new web site. I've created within DW CS4 5 templates for the 5 areas/topics the site will focus on. The site is not yet online. The problem is once I create my pages from the templates and save them all to the same folder called TEAM2 the links will not work between the separate template created pages. I've only worked with DW MX04 up tp this point. Never had a problem getting separate template created pages to work together until now. It seems even though the pages are saved to the TEAM2 folder they don't recognize it. They recognize the document folder. What do you think I'm doing wrong?
        • 2. Re: Separate Template Created Pages Won't Link
          covenant2 Level 1
          The code for the template is below:
          <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
          "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
          <!-- saved from url=(0014)about:internet -->
          <html xmlns="http://www.w3.org/1999/xhtml">
          <head>
          <!-- TemplateBeginEditable name="doctitle" -->
          <title>Gary Whetstone Worldwide Ministries</title>
          <!-- TemplateEndEditable -->
          <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
          <!--Fireworks CS3 Dreamweaver CS3 target.  Created Mon Feb 22 11:00:03 GMT-0500 (Eastern Standard Time) 2010-->
          <script language="JavaScript1.2" type="text/javascript">
          function MM_preloadImages() { //v3.0
            var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
              var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
              if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
          function MM_findObj(n, d) { //v4.01
            var p,i,x;  if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
              d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
            if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
            for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
            if(!x && d.getElementById) x=d.getElementById(n); return x;
          function MM_nbGroup(event, grpName) { //v6.0
            var i,img,nbArr,args=MM_nbGroup.arguments;
            if (event == "init" && args.length > 2) {
              if ((img = MM_findObj(args[2])) != null && !img.MM_init) {
                img.MM_init = true; img.MM_up = args[3]; img.MM_dn = img.src;
                if ((nbArr = document[grpName]) == null) nbArr = document[grpName] = new Array();
                nbArr[nbArr.length] = img;
                for (i=4; i < args.length-1; i+=2) if ((img = MM_findObj(args[i])) != null) {
                  if (!img.MM_up) img.MM_up = img.src;
                  img.src = img.MM_dn = args[i+1];
            } else if (event == "over") {
              document.MM_nbOver = nbArr = new Array();
              for (i=1; i < args.length-1; i+=3) if ((img = MM_findObj(args[i])) != null) {
                img.src = (img.MM_dn && args[i+2]) ? args[i+2] : ((args[i+1])? args[i+1] : img.MM_up);
            } else if (event == "out" ) {
              for (i=0; i < document.MM_nbOver.length; i++) {
                img = document.MM_nbOver[i]; img.src = (img.MM_dn) ? img.MM_dn : img.MM_up; }
            } else if (event == "down") {
              nbArr = document[grpName];
              if (nbArr)
                for (i=0; i < nbArr.length; i++) { img=nbArr[i]; img.src = img.MM_up; img.MM_dn = 0; }
              document[grpName] = nbArr = new Array();
              for (i=2; i < args.length-1; i+=2) if ((img = MM_findObj(args[i])) != null) {
                img.src = img.MM_dn = (args[i+1])? args[i+1] : img.MM_up;
          </script>
          <script language="JavaScript1.2" type="text/javascript" src="../mm_css_menu.js"></script>
          <style type="text/css" media="screen">
              @import url("../z_Header_main.css");
          </style>
          <link href="../gwwm.css" rel="stylesheet" type="text/css" />
          <!-- TemplateBeginEditable name="head" -->
          </head>
          <body bgcolor="#ffffff" onload="MM_preloadImages('../images/z_Header_main_r2_c7_f3.jpg','../images/z_Header_main_ r2_c7_f2.jpg','../images/z_Header_main_r2_c7_f4.jpg','../images/z_Header_main_r2_c11_f3.jp g','../images/z_Header_main_r2_c11_f2.jpg','../images/z_Header_main_r2_c11_f4.jpg','../ima ges/z_Header_main_r2_c15_f3.jpg','../images/z_Header_main_r2_c15_f2.jpg','../images/z_Head er_main_r2_c15_f4.jpg','../images/z_Header_main_r2_c19_f3.jpg','../images/z_Header_main_r2 _c19_f2.jpg','../images/z_Header_main_r2_c19_f4.jpg','../images/z_Header_main_r2_c22_f3.jp g','../images/z_Header_main_r2_c22_f2.jpg','../images/z_Header_main_r2_c22_f4.jpg','../ima ges/z_Header_main_r2_c24_f3.jpg','../images/z_Header_main_r2_c24_f2.jpg','../images/z_Head er_main_r2_c24_f4.jpg','../images/z_Header_main_r2_c26_f3.jpg','../images/z_Header_main_r2 _c26_f2.jpg','../images/z_Header_main_r2_c26_f4.jpg','../images/z_Header_main_r3_c4_f3.jpg ','../images/z_Header_main_r3_c4_f2.jpg','../images/z_Header_main_r3_c4_f4.jpg','../images /z_Header_main_r6_c2_f3.jpg','../images/z_Header_main_r6_c2_f2.jpg','../images/z_Header_ma in_r6_c2_f4.jpg','../images/z_Header_main_r8_c5_f3.jpg','../images/z_Header_main_r8_c5_f2. jpg','../images/z_Header_main_r8_c5_f4.jpg','../images/z_Header_main_r8_c9_f3.jpg','../ima ges/z_Header_main_r8_c9_f2.jpg','../images/z_Header_main_r8_c9_f4.jpg','../images/z_Header _main_r8_c14_f3.jpg','../images/z_Header_main_r8_c14_f2.jpg','../images/z_Header_main_r8_c 14_f4.jpg','../images/z_Header_main_r8_c17_f3.jpg','../images/z_Header_main_r8_c17_f2.jpg' ,'../images/z_Header_main_r8_c17_f4.jpg')">
          <table width="905" border="0" align="center" cellpadding="0" cellspacing="0">
            <tr>
              <td align="left" valign="top"><div id="FWTableContainer81665825">
                <table border="0" cellpadding="0" cellspacing="0" width="904">
                  <!-- fwtable fwsrc="MAIN HEADER.png" fwpage="Page 1" fwbase="z_Header_main.jpg" fwstyle="Dreamweaver" fwdocid = "81665825" fwnested="0" -->
                  <tr>
                    <td><img src="../images/spacer.gif" width="35" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="108" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="32" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="1" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="36" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="6" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="49" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="9" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="52" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="73" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="8" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="4" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="65" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="15" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="12" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="81" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="3" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="92" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="76" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="2" height="1" border="0" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="64" height="1" border="0" alt="" /></td>
                  </tr>
                  <tr>
                    <td colspan="27"><img name="z_Header_main_r1_c1" src="../images/z_Header_main_r1_c1.jpg" width="904" height="28" border="0" id="z_Header_main_r1_c1" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="1" height="28" border="0" alt="" /></td>
                  </tr>
                  <tr>
                    <td colspan="6"><img name="z_Header_main_r2_c1" src="../images/z_Header_main_r2_c1.jpg" width="218" height="1" border="0" id="z_Header_main_r2_c1" alt="" /></td>
                    <td rowspan="2" colspan="3"><a href="file:///C|/Users/David J/Documents/do_you_know_jesus.aspx" target="_top" onmouseout="MM_nbGroup('out');MM_menuStartTimeout(1000);" onmouseover="MM_menuShowMenu('MMMenuContainer0218150316_0', 'MMMenu0218150316_0',0,19,'z_Header_main_r2_c7');MM_nbGroup('over','z_Header_main_r2_c7', '../images/z_Header_main_r2_c7_f2.jpg','../images/z_Header_main_r2_c7_f4.jpg',1)" onclick="MM_nbGroup('down','navbar1','z_Header_main_r2_c7','../images/z_Header_main_r2_c7 _f3.jpg',1)"><img name="z_Header_main_r2_c7" src="../images/z_Header_main_r2_c7.jpg" width="110" height="16" border="0" id="z_Header_main_r2_c7" alt="Do you know Jesus" /></a></td>
                    <td rowspan="6"><img name="z_Header_main_r2_c10" src="../images/z_Header_main_r2_c10.jpg" width="6" height="239" border="0" id="z_Header_main_r2_c10" alt="" /></td>
                    <td rowspan="3" colspan="2"><a href="file:///C|/Users/David J/Documents/about_gwwm.aspx" target="_top" onmouseout="MM_nbGroup('out');MM_menuStartTimeout(1000);" onmouseover="MM_menuShowMenu('MMMenuContainer0218150316_1', 'MMMenu0218150316_1',0,19,'z_Header_main_r2_c11');MM_nbGroup('over','z_Header_main_r2_c11 ','../images/z_Header_main_r2_c11_f2.jpg','../images/z_Header_main_r2_c11_f4.jpg',1)" onclick="MM_nbGroup('down','navbar1','z_Header_main_r2_c11','../images/z_Header_main_r2_c 11_f3.jpg',1)"><img name="z_Header_main_r2_c11" src="../images/z_Header_main_r2_c11.jpg" width="81" height="19" border="0" id="z_Header_main_r2_c11" alt="About GWWM" /></a></td>
                    <td rowspan="6" colspan="2"><img name="z_Header_main_r2_c13" src="../images/z_Header_main_r2_c13.jpg" width="5" height="239" border="0" id="z_Header_main_r2_c13" alt="" /></td>
                    <td rowspan="3" colspan="3"><a href="file:///C|/Users/David J/Documents/online_donations.aspx" target="_top" onmouseout="MM_nbGroup('out');MM_menuStartTimeout(1000);" onmouseover="MM_menuShowMenu('MMMenuContainer0218150316_2', 'MMMenu0218150316_2',0,19,'z_Header_main_r2_c15');MM_nbGroup('over','z_Header_main_r2_c15 ','../images/z_Header_main_r2_c15_f2.jpg','../images/z_Header_main_r2_c15_f4.jpg',1)" onclick="MM_nbGroup('down','navbar1','z_Header_main_r2_c15','../images/z_Header_main_r2_c 15_f3.jpg',1)"><img name="z_Header_main_r2_c15" src="../images/z_Header_main_r2_c15.jpg" width="95" height="19" border="0" id="z_Header_main_r2_c15" alt="Online Donations" /></a></td>
                    <td rowspan="6"><img name="z_Header_main_r2_c18" src="../images/z_Header_main_r2_c18.jpg" width="6" height="239" border="0" id="z_Header_main_r2_c18" alt="" /></td>
                    <td rowspan="3" colspan="2"><a href="file:///C|/Users/David J/Documents/prayer_requests.aspx" target="_top" onmouseout="MM_nbGroup('out');" onmouseover="MM_nbGroup('over','z_Header_main_r2_c19','../images/z_Header_main_r2_c19_f2. jpg','../images/z_Header_main_r2_c19_f4.jpg',1)" onclick="MM_nbGroup('down','navbar1','z_Header_main_r2_c19','../images/z_Header_main_r2_c 19_f3.jpg',1)"><img name="z_Header_main_r2_c19" src="../images/z_Header_main_r2_c19.jpg" width="93" height="19" border="0" id="z_Header_main_r2_c19" alt="Prayer Requests" /></a></td>
                    <td rowspan="9"><img name="z_Header_main_r2_c21" src="../images/z_Header_main_r2_c21.jpg" width="3" height="273" border="0" id="z_Header_main_r2_c21" alt="" /></td>
                    <td rowspan="3"><a href="file:///C|/Users/David J/Documents/events_calendar.aspx" target="_top" onmouseout="MM_nbGroup('out');MM_menuStartTimeout(1000);" onmouseover="MM_menuShowMenu('MMMenuContainer0218150316_3', 'MMMenu0218150316_3',0,19,'z_Header_main_r2_c22');MM_nbGroup('over','z_Header_main_r2_c22 ','../images/z_Header_main_r2_c22_f2.jpg','../images/z_Header_main_r2_c22_f4.jpg',1)" onclick="MM_nbGroup('down','navbar1','z_Header_main_r2_c22','../images/z_Header_main_r2_c 22_f3.jpg',1)"><img name="z_Header_main_r2_c22" src="../images/z_Header_main_r2_c22.jpg" width="92" height="19" border="0" id="z_Header_main_r2_c22" alt="Events Calendar" /></a></td>
                    <td rowspan="9"><img name="z_Header_main_r2_c23" src="../images/z_Header_main_r2_c23.jpg" width="4" height="273" border="0" id="z_Header_main_r2_c23" alt="" /></td>
                    <td rowspan="3"><a href="file:///C|/Users/David J/Documents/media_center.aspx" target="_top" onmouseout="MM_nbGroup('out');MM_menuStartTimeout(1000);" onmouseover="MM_menuShowMenu('MMMenuContainer0218150316_4', 'MMMenu0218150316_4',0,19,'z_Header_main_r2_c24');MM_nbGroup('over','z_Header_main_r2_c24 ','../images/z_Header_main_r2_c24_f2.jpg','../images/z_Header_main_r2_c24_f4.jpg',1)" onclick="MM_nbGroup('down','navbar1','z_Header_main_r2_c24','../images/z_Header_main_r2_c 24_f3.jpg',1)"><img name="z_Header_main_r2_c24" src="../images/z_Header_main_r2_c24.jpg" width="76" height="19" border="0" id="z_Header_main_r2_c24" alt="Media Center" /></a></td>
                    <td rowspan="9"><img name="z_Header_main_r2_c25" src="../images/z_Header_main_r2_c25.jpg" width="2" height="273" border="0" id="z_Header_main_r2_c25" alt="" /></td>
                    <td rowspan="3"><a href="file:///C|/Users/David J/Documents/contact_us.aspx" target="_top" onmouseout="MM_nbGroup('out');MM_menuStartTimeout(1000);" onmouseover="MM_menuShowMenu('MMMenuContainer0218150316_5', 'MMMenu0218150316_5',0,19,'z_Header_main_r2_c26');MM_nbGroup('over','z_Header_main_r2_c26 ','../images/z_Header_main_r2_c26_f2.jpg','../images/z_Header_main_r2_c26_f4.jpg',1)" onclick="MM_nbGroup('down','navbar1','z_Header_main_r2_c26','../images/z_Header_main_r2_c 26_f3.jpg',1)"><img name="z_Header_main_r2_c26" src="../images/z_Header_main_r2_c26.jpg" width="64" height="19" border="0" id="z_Header_main_r2_c26" alt="Contact Us" /></a></td>
                    <td rowspan="9"><img name="z_Header_main_r2_c27" src="../images/z_Header_main_r2_c27.jpg" width="49" height="273" border="0" id="z_Header_main_r2_c27" alt="" /></td>
                  </tr>
                  <tr>
                    <td rowspan="3" colspan="3"><img name="z_Header_main_r3_c1" src="../images/z_Header_main_r3_c1.jpg" width="175" height="57" border="0" id="z_Header_main_r3_c1" alt="" /></td>
                    <td rowspan="2" colspan="2"><a href="file:///C|/Users/David J/Documents/index.aspx" target="_top" onmouseout="MM_nbGroup('out');" onmouseover="MM_nbGroup('over','z_Header_main_r3_c4','../images/z_Header_main_r3_c4_f2.jp g','../images/z_Header_main_r3_c4_f4.jpg',1)" onclick="MM_nbGroup('down','navbar1','z_Header_main_r3_c4','../images/z_Header_main_r3_c4 _f3.jpg',1)"><img name="z_Header_main_r3_c4" src="../images/z_Header_main_r3_c4.jpg" width="37" height="18" border="0" id="z_Header_main_r3_c4" alt="Home" /></a></td>
                    <td rowspan="5"><img name="z_Header_main_r3_c6" src="../images/z_Header_main_r3_c6.jpg" width="6" height="238" border="0" id="z_Header_main_r3_c6" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="1" height="15" border="0" alt="" /></td>
                  </tr>
                  <tr>
                    <td rowspan="4" colspan="3"><img name="z_Header_main_r4_c7" src="../images/z_Header_main_r4_c7.jpg" width="110" height="223" border="0" id="z_Header_main_r4_c7" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="1" height="3" border="0" alt="" /></td>
                  </tr>
                  <tr>
                    <td rowspan="3" colspan="2"><img name="z_Header_main_r5_c4" src="../images/z_Header_main_r5_c4.jpg" width="37" height="220" border="0" id="z_Header_main_r5_c4" alt="" /></td>
                    <td rowspan="3" colspan="2"><img name="z_Header_main_r5_c11" src="../images/z_Header_main_r5_c11.jpg" width="81" height="220" border="0" id="z_Header_main_r5_c11" alt="" /></td>
                    <td rowspan="3" colspan="3"><img name="z_Header_main_r5_c15" src="../images/z_Header_main_r5_c15.jpg" width="95" height="220" border="0" id="z_Header_main_r5_c15" alt="" /></td>
                    <td rowspan="3" colspan="2"><img name="z_Header_main_r5_c19" src="../images/z_Header_main_r5_c19.jpg" width="93" height="220" border="0" id="z_Header_main_r5_c19" alt="" /></td>
                    <td rowspan="6"><img name="z_Header_main_r5_c22" src="../images/z_Header_main_r5_c22.jpg" width="92" height="254" border="0" id="z_Header_main_r5_c22" alt="" /></td>
                    <td rowspan="6"><img name="z_Header_main_r5_c24" src="../images/z_Header_main_r5_c24.jpg" width="76" height="254" border="0" id="z_Header_main_r5_c24" alt="" /></td>
                    <td rowspan="6"><img name="z_Header_main_r5_c26" src="../images/z_Header_main_r5_c26.jpg" width="64" height="254" border="0" id="z_Header_main_r5_c26" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="1" height="39" border="0" alt="" /></td>
                  </tr>
                  <tr>
                    <td rowspan="5"><img name="z_Header_main_r6_c1" src="../images/z_Header_main_r6_c1.jpg" width="35" height="215" border="0" id="z_Header_main_r6_c1" alt="" /></td>
                    <td><a href="file:///C|/Users/David J/Documents/index.aspx" target="_top" onmouseout="MM_nbGroup('out');" onmouseover="MM_nbGroup('over','z_Header_main_r6_c2','../images/z_Header_main_r6_c2_f2.jp g','../images/z_Header_main_r6_c2_f4.jpg',1)" onclick="MM_nbGroup('down','navbar1','z_Header_main_r6_c2','../images/z_Header_main_r6_c2 _f3.jpg',1)"><img name="z_Header_main_r6_c2" src="../images/z_Header_main_r6_c2.jpg" width="108" height="108" border="0" id="z_Header_main_r6_c2" alt="Home Page" /></a></td>
                    <td rowspan="5"><img name="z_Header_main_r6_c3" src="../images/z_Header_main_r6_c3.jpg" width="32" height="215" border="0" id="z_Header_main_r6_c3" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="1" height="108" border="0" alt="" /></td>
                  </tr>
                  <tr>
                    <td rowspan="4"><img name="z_Header_main_r7_c2" src="../images/z_Header_main_r7_c2.jpg" width="108" height="107" border="0" id="z_Header_main_r7_c2" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="1" height="73" border="0" alt="" /></td>
                  </tr>
                  <tr>
                    <td rowspan="3"><img name="z_Header_main_r8_c4" src="../images/z_Header_main_r8_c4.jpg" width="1" height="34" border="0" id="z_Header_main_r8_c4" alt="" /></td>
                    <td colspan="3"><a href="file:///C|/Users/David J/Documents/gwwm_missions.aspx" target="_top" onmouseout="MM_nbGroup('out');" onmouseover="MM_nbGroup('over','z_Header_main_r8_c5','../images/z_Header_main_r8_c5_f2.jp g','../images/z_Header_main_r8_c5_f4.jpg',1)" onclick="MM_nbGroup('down','navbar1','z_Header_main_r8_c5','../images/z_Header_main_r8_c5 _f3.jpg',1)"><img name="z_Header_main_r8_c5" src="../images/z_Header_main_r8_c5.jpg" width="91" height="16" border="0" id="z_Header_main_r8_c5" alt="" /></a></td>
                    <td rowspan="3"><img name="z_Header_main_r8_c8" src="../images/z_Header_main_r8_c8.jpg" width="9" height="34" border="0" id="z_Header_main_r8_c8" alt="" /></td>
                    <td rowspan="2" colspan="3"><a href="file:///C|/Users/David J/Documents/victory_christian_network.aspx" target="_top" onmouseout="MM_nbGroup('out');" onmouseover="MM_nbGroup('over','z_Header_main_r8_c9','../images/z_Header_main_r8_c9_f2.jp g','../images/z_Header_main_r8_c9_f4.jpg',1)" onclick="MM_nbGroup('down','navbar1','z_Header_main_r8_c9','../images/z_Header_main_r8_c9 _f3.jpg',1)"><img name="z_Header_main_r8_c9" src="../images/z_Header_main_r8_c9.jpg" width="131" height="19" border="0" id="z_Header_main_r8_c9" alt="Victory Christian Church Network" /></a></td>
                    <td rowspan="3" colspan="2"><img name="z_Header_main_r8_c12" src="../images/z_Header_main_r8_c12.jpg" width="9" height="34" border="0" id="z_Header_main_r8_c12" alt="" /></td>
                    <td rowspan="2" colspan="2"><a href="http://www.schoolofbiblicalstudies.com/" target="_blank" onmouseout="MM_nbGroup('out');" onmouseover="MM_nbGroup('over','z_Header_main_r8_c14','../images/z_Header_main_r8_c14_f2. jpg','../images/z_Header_main_r8_c14_f4.jpg',1)" onclick="MM_nbGroup('down','navbar1','z_Header_main_r8_c14','../images/z_Header_main_r8_c 14_f3.jpg',1)"><img name="z_Header_main_r8_c14" src="../images/z_Header_main_r8_c14.jpg" width="69" height="19" border="0" id="z_Header_main_r8_c14" alt="GWWM School of Biblical Studies" /></a></td>
                    <td rowspan="3"><img name="z_Header_main_r8_c16" src="../images/z_Header_main_r8_c16.jpg" width="15" height="34" border="0" id="z_Header_main_r8_c16" alt="" /></td>
                    <td rowspan="2" colspan="3"><a href="file:///C|/Users/David J/Documents/store.aspx" target="_top" onmouseout="MM_nbGroup('out');" onmouseover="MM_nbGroup('over','z_Header_main_r8_c17','../images/z_Header_main_r8_c17_f2. jpg','../images/z_Header_main_r8_c17_f4.jpg',1)" onclick="MM_nbGroup('down','navbar1','z_Header_main_r8_c17','../images/z_Header_main_r8_c 17_f3.jpg',1)"><img name="z_Header_main_r8_c17" src="../images/z_Header_main_r8_c17.jpg" width="33" height="19" border="0" id="z_Header_main_r8_c17" alt="Store" /></a></td>
                    <td rowspan="3"><img name="z_Header_main_r8_c20" src="../images/z_Header_main_r8_c20.jpg" width="81" height="34" border="0" id="z_Header_main_r8_c20" alt="" /></td>
                    <td><img src="../images/spacer.gif" width="1" height="16" border="0" alt="" /></td>
                  </tr>
                  <tr>
                    <td rowspan="2" colspan="3"><img name="z_Header_main_r9_c5" src="../images/z_Header_main_r9_c5.jpg" width="91" height="18" border="0" id="z_Header_main_r9_c5" alt="" /></td>
                  </tr>
                  <tr>
                    <td colspan="3"><img name="z_Header_main_r10_c9" src="../images/z_Header_main_r10_c9.jpg" width="131" height="15" border="0" id="z_Header_main_r10_c9" alt="" /></td>
                    <td colspan="2"><img name="z_Header_main_r10_c14" src="../images/z_Header_main_r10_c14.jpg" width="69" height="15" border="0" id="z_Header_main_r10_c14" alt="" /></td>
                    <td colspan="3"><img name="z_Header_main_r10_c17" src="../images/z_Header_main_r10_c17.jpg" width="33" height="15" border="0" id="z_Header_main_r10_c17" alt="" /></td>
                  </tr>
                </table>
                <div id="MMMenuContainer0218150316_0">
                  <div id="MMMenu0218150316_0" onmouseout="MM_menuStartTimeout(1000);" onmouseover="MM_menuResetTimeout();"> <a href="file:///C|/Users/David J/Documents/daily_manna.aspx" id="MMMenu0218150316_0_Item_0" class="MMMIFVStyleMMMenu0218150316_0" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_0');"> Daily Manna </a> <a href="file:///C|/Users/David J/Documents/bible_helps.aspx" id="MMMenu0218150316_0_Item_1" class="MMMIVStyleMMMenu0218150316_0" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_0');"> Bible Helps </a> <a href="file:///C|/Users/David J/Documents/chronological_bible.aspx" id="MMMenu0218150316_0_Item_2" class="MMMIVStyleMMMenu0218150316_0" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_0');"> Chronological Bible </a> <a href="file:///C|/Users/David J/Documents/virtual_bible.aspx" id="MMMenu0218150316_0_Item_3" class="MMMIVStyleMMMenu0218150316_0" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_0');"> Virtual Bible </a> </div>
                </div>
                <div id="MMMenuContainer0218150316_1">
                  <div id="MMMenu0218150316_1" onmouseout="MM_menuStartTimeout(1000);" onmouseover="MM_menuResetTimeout();"> <a href="file:///C|/Users/David J/Documents/dr_gary_whetstones_bio.aspx" id="MMMenu0218150316_1_Item_0" class="MMMIFVStyleMMMenu0218150316_1" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_1');"> Dr. Gary Whetstone's Bio </a> <a href="file:///C|/Users/David J/Documents/pastor_faye_whetstones_bio.aspx" id="MMMenu0218150316_1_Item_1" class="MMMIVStyleMMMenu0218150316_1" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_1');"> Pastor Faye Whetstone's Bio </a> <a href="file:///C|/Users/David J/Documents/magazine_article.aspx" id="MMMenu0218150316_1_Item_2" class="MMMIVStyleMMMenu0218150316_1" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_1');"> Magazine article </a> <a href="file:///C|/Users/David J/Documents/location_and_directions.aspx" id="MMMenu0218150316_1_Item_3" class="MMMIVStyleMMMenu0218150316_1" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_1');"> Location and Directions </a> <a href="file:///C|/Users/David J/Documents/service_times.aspx" id="MMMenu0218150316_1_Item_4" class="MMMIVStyleMMMenu0218150316_1" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_1');"> Service Times </a> <a href="file:///C|/Users/David J/Documents/what_we_believe.aspx" id="MMMenu0218150316_1_Item_5" class="MMMIVStyleMMMenu0218150316_1" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_1');"> What We Believe </a> <a href="file:///C|/Users/David J/Documents/history.aspx" id="MMMenu0218150316_1_Item_6" class="MMMIVStyleMMMenu0218150316_1" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_1');"> History </a> <a href="file:///C|/Users/David J/Documents/publishing_reuests.aspx" id="MMMenu0218150316_1_Item_7" class="MMMIVStyleMMMenu0218150316_1" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_1');"> Publishing Requests </a> <a href="file:///C|/Users/David J/Documents/press_release.aspx" id="MMMenu0218150316_1_Item_8" class="MMMIVStyleMMMenu0218150316_1" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_1');"> Press Release </a> <a href="file:///C|/Users/David J/Documents/privacy_statement.aspx" id="MMMenu0218150316_1_Item_9" class="MMMIVStyleMMMenu0218150316_1" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_1');"> Privacy Statement </a> </div>
                </div>
                <div id="MMMenuContainer0218150316_2">
                  <div id="MMMenu0218150316_2" onmouseout="MM_menuStartTimeout(1000);" onmouseover="MM_menuResetTimeout();"> <a href="file:///C|/Users/David J/Documents/eagle_partners.aspx" id="MMMenu0218150316_2_Item_0" class="MMMIFVStyleMMMenu0218150316_2" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_2');"> Eagle Partners </a> </div>
                </div>
                <div id="MMMenuContainer0218150316_3">
                  <div id="MMMenu0218150316_3" onmouseout="MM_menuStartTimeout(1000);" onmouseover="MM_menuResetTimeout();"> <a href="file:///C|/Users/David J/Documents/annual_evets.aspx" id="MMMenu0218150316_3_Item_0" class="MMMIFVStyleMMMenu0218150316_3" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_3');"> Annual Events </a> <a href="file:///C|/Users/David J/Documents/guest_appearances.aspx" id="MMMenu0218150316_3_Item_1" class="MMMIVStyleMMMenu0218150316_3" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_3');"> Guest Appearances </a> <a href="file:///C|/Users/David J/Documents/paid_event_registration.aspx" id="MMMenu0218150316_3_Item_2" class="MMMIVStyleMMMenu0218150316_3" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_3');"> Paid Event Registration </a> </div>
                </div>
                <div id="MMMenuContainer0218150316_4">
                  <div id="MMMenu0218150316_4" onmouseout="MM_menuStartTimeout(1000);" onmouseover="MM_menuResetTimeout();"> <a href="file:///C|/Users/David J/Documents/live_services.aspx" id="MMMenu0218150316_4_Item_0" class="MMMIFVStyleMMMenu0218150316_4" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_4');"> Live Services </a> <a href="file:///C|/Users/David J/Documents/video_archives.aspx" id="MMMenu0218150316_4_Item_1" class="MMMIVStyleMMMenu0218150316_4" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_4');"> Video Archives </a> <a href="file:///C|/Users/David J/Documents/photo_gallery.aspx" id="MMMenu0218150316_4_Item_2" class="MMMIVStyleMMMenu0218150316_4" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_4');"> Photo Gallery </a> </div>
                </div>
                <div id="MMMenuContainer0218150316_5">
                  <div id="MMMenu0218150316_5" onmouseout="MM_menuStartTimeout(1000);" onmouseover="MM_menuResetTimeout();"> <a href="file:///C|/Users/David J/Documents/site_map.aspx" id="MMMenu0218150316_5_Item_0" class="MMMIFVStyleMMMenu0218150316_5" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_5');"> Site Map </a> <a href="file:///C|/Users/David J/Documents/employment_opportunities.aspx" id="MMMenu0218150316_5_Item_1" class="MMMIVStyleMMMenu0218150316_5" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_5');"> Employment Opportunities </a> <a href="file:///C|/Users/David J/Documents/volunteer_opportunities.aspx" id="MMMenu0218150316_5_Item_2" class="MMMIVStyleMMMenu0218150316_5" onmouseover="MM_menuOverMenuItem('MMMenu0218150316_5');"> Volunteer Opportunities </a> </div>
                </div>
              </div></td>
            </tr>
            <tr>
              <td align="left" valign="top"><table width="886" border="0" cellspacing="0" cellpadding="0">
                <tr>
                  <td width="15"> </td>
                  <td width="871"><!-- TemplateBeginEditable name="EditRegion1" -->EditRegion1<!-- TemplateEndEditable --></td>
                </tr>
              </table></td>
            </tr>
            <tr>
              <td align="center" valign="top"><h6><a href="file:///C|/Users/David J/Documents/index.html">Gary Whetstone Worldwide Ministries</a> • 100    Wilton Boulevard • New Castle,   DE 19720<br />
                (302) 324.5400 • (800) 383.4223 • ©2007 - 2010 GWWM. All  Rights Reserved. <br />
            <a href="file:///C|/Users/David J/Documents/contact_us.html">Contact </a>• <a href="file:///C|/Users/David J/Documents/privacy_statement.html">Privacy Policy</a> • <a href="file:///C|/Users/David J/Documents/terms_and_conditions.html">Terms &amp; Conditions</a> • Site by:  GWWM Graphics Department</h6></td>
            </tr>
          </table>
          </body>
          </html>
          • 3. Re: Separate Template Created Pages Won't Link
            Ken Binney-GnPIX3 Level 4
            You are linking to filed on your hard drive rather than files on the server
            For example <a href="file:///C|/Users/David J/Documents/
            • 4. Re: Separate Template Created Pages Won't Link
              covenant2 Level 1
              If I take out this line of code from the template the pages work: file:///C|/Users/David J/Documents/
              But why does DW add it anyway? And how can I prevent this in the future?
              dj
              • 5. Re: Separate Template Created Pages Won't Link
                covenant2 Level 1
                OK, I get it. Thanks much!
                • 6. Re: Separate Template Created Pages Won't Link
                  Hopefully a Templates experienced person may reply,
                  Had you already defined the site in Sites Manager prior to coding the templates?
