3 Replies Latest reply on Nov 28, 2007 11:50 AM by Damon Edwards
    Need Action Script
    necie Level 1
      What actions script would I use to load movie_B.swf, frame 200 into my main timeline? I want to skip the first 199 frames of movie_B.swf when loaded.
        • 1. Re: Need Action Script
          Damon Edwards Level 3
          use the MovieClipLoader class to load the external SWF file. Use its onLoadInit() event to send it to frame 200.
          • 2. Re: Need Action Script
            necie Level 1
            I'm having a little problem understanding the MovieClipLoader class. I'm more of an amateur when it comes to AS. I'm using Script Assist as well... Here's as far as I got.
            on (release) {
            not_set_yet.onLoadInit = function(target) {
            FOR THE FIRST PART.... not_set_yet.loadClip(movie_B.swf,1);
            1 - I'm not sure what the "Object" should be (where the "not_set_yet" is in the AS)
            2 - I'm pretty sure the "URL" should be the actual name of my loaded .swf
            3 - I'm assuming the "Target" is the level... is that correct?
            FOR THE FIRST PART....not_set_yet.onLoadInit = function(target)
            1 - Should the "Object:" be the frame (where it says 'not yet set') I want to load? If not what is this?
            2 - The next two lines filled themselves in with for the Method and Parameters
            Any help is greatly appreciated.
            • 3. Re: Need Action Script
