1 Reply Latest reply on Feb 23, 2010 2:39 PM by kglad
    A few questions about using an XML file to add text into a TextArea component set as html
      I'm using AS2 in Flash CS3.
      I have a TextArea component in the stage that's loading its text from an XML and I've been able to use the ul and li tags to create lists. However, when I try to include a nested list it just inserts a line break between the nested list and the main list rather than indent it further. Is there a solution for this issue?
      Failing that, how would I be able to add non-breaking spaces into the XML so they will render inside the TextArea component? I've tried   and   without success. I scoured the net for some help with this and found some information about modifying the font embedding xml file with a new entry for the non-breaking space and that didn't work either, so that leaves me somewhat stumped.
