0 Replies Latest reply on Feb 23, 2010 2:37 PM by kevinklin
    [svn:fx-trunk] 14371: Merge revision 14369 from 4.x to trunk
    kevinklin Adobe Employee
      Revision: 14371
      Revision: 14371
      Author:   klin@adobe.com
      Date:     2010-02-23 14:37:38 -0800 (Tue, 23 Feb 2010)
      Log Message:
      Fix for icons that shouldn't be mirroring. This fix is similar to the one found in UITextField Modified FlexBitmap to detect whether the closest parent is mirrored when added to the display list, and adjust the transform matrix accordingly. Also, I overrode the x, width, and height properties to again, adjust the transform matrix when necessary.
      http://bugs.adobe.com/jira/browse/SDK-25417 - Button icons
      http://bugs.adobe.com/jira/browse/SDK-25498 - Alert icons
      http://bugs.adobe.com/jira/browse/SDK-25511 - Accordion icons
      http://bugs.adobe.com/jira/browse/SDK-25512 - ComboBox icons
      QE notes: None
      Doc notes: None
      Bugs: SDK-25417, SDK-25498, SDK-25511, SDK-25512
      Reviewed By: Hans
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/FlexBitmap.as
      Property Changed:
          flex/sdk/trunk/
