0 Replies Latest reply on Feb 23, 2010 4:35 PM by Jason Szeto
    [svn:fx-trunk] 14377: Merging revision 14376 from 4.x to trunk
    Jason Szeto Level 3
      Revision: 14377
      Revision: 14377
      Author:   jszeto@adobe.com
      Date:     2010-02-23 16:35:29 -0800 (Tue, 23 Feb 2010)
      Log Message:
      Mirroring bug fixes
      http://bugs.adobe.com/jira/browse/SDK-25427 - HTML AIR component should not be mirrored even when layoutDirection=rtl
      Set layoutDirection=ltr in defaults.css
      http://bugs.adobe.com/jira/browse/SDK-25626 - The Spark VSlider dataTip is not positioned correctly when layoutDirection=rtl. It obscures the thumb.
      Translate the position from mirrored local coordinate to global coordinates.
      http://bugs.adobe.com/jira/browse/SDK-25584 - MX MenuBar displays menus offscreen when layoutDirection is rtl
      Added logic to keep the menus from going off the left side of the screen.
      QE notes: none
      Doc notes: none
      Bugs: SDK-25427, SDK-25626, SDK-25584
      Reviewer: Hans
      Tests run: checkintests
      Is noteworthy for integration: no
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/defaults.css
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/MenuBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VSlider.as
      Property Changed:
          flex/sdk/trunk/
