2 Replies Latest reply on Feb 24, 2010 6:30 AM by the_wine_snob
    Creating ISO ?
      Is it possible to burn a ISO file directly from Pr. Elements 8 ?
        • 1. Re: Creating ISO ?
          nealeh Level 5
          This isn't possible unless you are using a Virtual Burner. Two mentioned several times in these forums are Virtual CD and Phantom Burner. These are commercial products - I don't recall ever hearing of a freeware burner.
          Unless you are working with Blu-Ray you can share your project to a folder (select Disk and then use the 'Burn to:' drop down to select Folder). You can then use your standard burning software to burn an ISO from that folder - just make sure your burning software is set for media and not data.
          • 2. Re: Creating ISO ?
            the_wine_snob Level 9
            Also, the free burning utility, ImgBurn, can write an ISO to a DVD, from that VIDEO_TS folder. If I need an ISO and the Project is in PrE, that is my workflow. Now, Adobe's full-featured authoring program, Encore, only bundled with PrPro, can directly write an ISO image. However, it is no longer offered as a stand-alone product.
