1 Reply Latest reply on Feb 24, 2010 11:16 AM by Kevin Goldsmith
    I'm trying to blend in a negative
    nikos101 Level 2
      I'm trying to blend in a negative with a normal image but am getting errors
      <languageVersion : 1.0;>
      kernel Crossfade
      <   namespace : "AIF";
          vendor : "Adobe Systems";
          version : 2;
          description : "Miz in inversion"; >
         parameter float intensity;
         input image4 src;
         output pixel4 dst;
         void evaluatePixel()
             float4 src=  sampleNearest(src, outCoord());
             float4 sr2=  sampleNearest(src, outCoord());
             src2.rgb=  float3(1.0, 1.0, 1.0) - src.rgb;
              dst = mix(src,src2, intensity);
      ERROR: (line 18): 'sampleNearest' : no matching overloaded function found
      ERROR: (line 18): '=' :  cannot convert from 'const float' to '4-component vector of float'
      ERROR: (line 20): 'src2' : undeclared identifier
      ERROR: (line 20): 'rgb' :  field selection requires structure, vector, or matrix on left hand side
      ERROR: (line 20): 'assign' :  cannot convert from '3-component vector of float' to 'float'
      ERROR: (line 23): 'mix' : no matching overloaded function found
      ERROR: (line 23): 'assign' :  cannot convert from 'const float' to 'output 4-component vector of float'
        • 1. Re: I'm trying to blend in a negative
          Kevin Goldsmith Level 3
          It looks like you modified the crossfade sample, but add a syntax error.
          I made two changes (rename variable "sr2" to be "src2" and not bother sampling the same pixel twice) and this seems to work fine:
          kernel Crossfade
              version : 2;
             input image4 src;
             output pixel4 dst;
                 float4 src2= src;
