0 Replies Latest reply on Feb 24, 2010 2:10 AM by JackFrost21
    Merge components into new media file
    JackFrost21
      This is probably not the right place for this given this forum is around front end code mostly but I have been pulling my hair out trying to find the right solution and I am hoping some of you will have had a similar requirement given what the framework allows you to do.
      I have built a flex application that takes an flv with cue points and an image which I specify and merges the two to put the image over the video when the cue point event fires - all pretty simple.
      Now I want to write this to a new media file that can be downloaded and played - can be any format (flv is fine). The solution needs to run in the backend i.e not through a GUI.
      I cannot seem to find a way to do this and I was hoping some of you folks might have come across something and could point me in the right direction.
