7 Replies Latest reply on Feb 24, 2010 11:46 PM by RoBbertDs1
    Split code from mxml
    RoBbertDs1
      Hi there
      I'm doing a school project in which I have to build a component that have multiple buttons on it like this on :
      <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml"
           toolTip="Blabla" width="230" height="200">
                <mx:Button id="buttonZoomIn" icon="@Embed(source='../Assets/Images/i_zoomin.png')" width="60" fillAlphas="[0.0, 0.0, 0.0, 0.0]" toolTip="Zoom in"  left="10" top="10" height="60"/>
                <mx:Button id="buttonZoomOut" right="10" icon="@Embed(source='../Assets/Images/i_zoomout.png')" width="60" fillAlphas="[0.0, 0.0, 0.0, 0.0]" fontWeight="bold" cornerRadius="4" alpha="1.0" fillColors="[#A6C1FA, #A6C1FA, #A6C1FA, #A6C1FA]" toolTip="Zoom out" top="10" height="60"/>
                <mx:Button label="Reset" id="buttonResetMap" toolTip="Reset map to original state" bottom="30" left="10" width="60" height="20"/>
      </mx:Canvas>
        • 1. Re: Split code from mxml
          Bogdan Manate Level 2
          Hi Robert,
          I think I don't understant the problem... What you really want to do ?
          • 2. Re: Split code from mxml
            RoBbertDs1 Level 1
            Text wasn't done yet
            Correct text (could not edit the text for some reason)
            Hi there
                      <mx:Button id="buttonZoomIn"  width="60"  toolTip="Zoom in"  left="10" top="10" height="60"/>
                      <mx:Button id="buttonZoomOut" right="10"  width="60" height="60"/>
                      <mx:Button label="Reset" id="buttonResetMap" toolTip="Reset map to original state"" width="60" height="20"/>
            </mx:Canvas>
            They want us to separate the code from the mxml file so I have a ComponentCode.as class
            the problem is here when I want to add an action listner to the button on the component it tells me that the button is null
            package Classes.ControlCode
                 imports ...
                 public class NavigationControlCode extends NavigationComponent
                      var's ...
                      public function NavigationControlCode()
                           //Event listeners for buttons
                                buttonZoomIn.addEventListener(MouseEvent.CLICK, zoomIn);
                                buttonZoomOut.addEventListener(MouseEvent.CLICK, zoomOut);
                                buttonResetMap.addEventListener(MouseEvent.CLICK, resetMap);
                            public function zoomIn():void
            Does someone know a solution to this
            Or is there a better way to do this ?
            • 3. Re: Split code from mxml
              Your class doesn't know who those buttons are. I think a simple solution
              would be to create an instance of NavigationControlCode in your component
              and to pass a reference to your canvas to NavigationControlCode constructor.
              Navigation.mxml
                   xmlns:control="Classes.ControlCode.*"
                       <control:NavigationControlCode  target="" />
              </mx:Canvas>
                   imports ...
                        var's ...
                        public var target :Navigation;
              zoomOut);
              resetMap);
              The code from above is not tested in Flex Builder, but I think it should
              work.
              • 4. Re: Split code from mxml
                RoBbertDs1 Level 1
                That didn't work
                It gives an error on the target="" in the tag of the controlCode
                If I leave that out it still gives the same error that the buttons are null :s
                So I don't know if there are other solutions to this problem, so now the fact is you have to add the NavigationControlCode  to your main page to see the Canvas with the buttons, and to have the code.
                Isn't it best that the component itself gets the information from NavigationControlCode  so that u can add the component to the main page instead (want to make libraries afterwards) ?
                • 6. Re: Split code from mxml
                  I forgot to say that you must add the event listeners this way:
                            var's ...
                            protected var _target :Navigation;
                            public function set target( value:Navigation ):void
                                  target = value;
                                     target.buttonZoomIn.addEventListener(MouseEvent.CLICK,
                  zoomIn);
                                     target.buttonZoomOut.addEventListener(MouseEvent.CLICK,
                  zoomOut);
                                     target.buttonResetMap.addEventListener(MouseEvent.CLICK,
                  resetMap);
                  And of course if you want a different approach you can read the articoles
                  wrote by Paul Williams.
                  • 7. Re: Split code from mxml
                    RoBbertDs1 Level 1
                    Thanks everyone for helping
                    The problem was solved by this : http://examples.pmwilliams.co.uk/adobeblog/presentationpatterns/codebehind/srcview/index.h tml
                    Thas is the code behind from the blogs about the code behind
                    The problem was that you have to add :
                    addEventListener( FlexEvent.CREATION_COMPLETE, creationCompleteHandler );
                    and then at the function creationCompleteHandler you van add the handlers to the buttons.
                    Greetings
