When connection pooling, (“Maintain Connections” in cfadmin) is enabled. Oracle Global Temporary tables get messed up. Data bleeds from one page request to the next because CF is reusing the same Oracle session over and over again.
Is there a JDBC driver that will allow the use of Global Temp Tables while having connection pooling enabled?
Other application servers, like Oracle Application Server, somehow allow the pooling and GTT work together harmoniously.
If your temporary tables were created with the default setting of on commit delete rows, the cftransaction tag will help you. This code:
<cfquery name="x" datasource="burns">
create global temporary table t_dan_test (id integer)
</cfquery>
<cftransaction>
<cfquery name="i" datasource="burns">
insert into t_dan_test values(1)
</cfquery>
<cfquery name="x1" datasource="burns">
select * from t_dan_test
</cfquery>
</cftransaction>
<cfquery name="x2" datasource="burns">
</cf
</cfquery>
<cftransaction>
</cfquery>
</cfquery>
</cftransaction>
</cfquery>
<cfdump var="#x1#">
<cfdump var="#x2#">
resulted in x1 dumping 1 record and x2 dumping 0.
