1 Reply Latest reply on Feb 24, 2010 11:00 AM by NTC Ann
    CS4 Illustrator Creating Outlines, Not Creating Outlines
    NTC Ann Level 1
      CS4 Illustrator, Mac OC 10.6.2
      Why when I type text and then try to create outlines, instead of creating outlines, I am getting a block that if I try to size by say moving the left side in, instead it thinks it is moving both sides in from the center (even though the upper L little box on the top of the tool bar is selected).
      And it won't let me select one letter even using the hollow arrow tool. It just thinks it is all one solid pc.
      And if I try to move that supposed create outlines of text even 1 pt., it won't move but says can't do it cause it will cause the object to go off the pasteboard (which it will not).
      Thanks for help.
