4 Replies Latest reply on Feb 27, 2010 11:15 AM by vale.perla
    HUD problems
    vale.perla
      I imported a file .ai but i have a problems with command HUD:
      i can covert artwork to component > button but I do not have the ability to change the action because the button
      "add action" doesn't work.
      So i don't know if my version is doesn't work or someone has the same problem
      thanks
        • 1. Re: HUD problems
          acath Level 4
          Hi Vale,
          I think you're looking in the wrong panel. The "Add Action" button is in the timelines panel, right? That button is for when you're editing a timeline, which you're not in this case.
          To add an interaction to the button (e.g. "when I click on this button, go to this other page"), select the button and then click "Add Interaction" in the interactions panel.
          -Adam
          • 2. Re: HUD problems
            vale.perla Level 1
            hi Adam
            thank you for reply
            but also command "add interaction" doesn't work, so when i click on hud
            convert artwork to component > button (up, down, over or disabled)
            i can't do anythig because also +add interaction doesn't work
            It is as if absence of commands
            like "on click" does not exist, in its place there is an empty space
            that i can not click
            i don't know
            i try to unistall and re-install the program three times
            but the problem is always the same
            • 3. Re: HUD problems
              acath Level 4
              Hi Vale,
              Try choosing "Window > Reset Workspace".
              -Adam
              • 4. Re: HUD problems
                vale.perla Level 1
                hi Adam
                thank you very much
                i resolved the problems after install for the fourth time catalyst
                maybe i did somethings wrong before
                thanks
