1 Reply Latest reply on Feb 24, 2010 3:24 PM by =VA=FyreHeart
    ADG - How to suppress some folders?
    Tawn Kramer
      I have an XML data tree I'm displaying. Some leaf nodes have child data that is used to drive a column display attribute. I don't necessarily want that data to be viewed with a folder icon.
      That might be enough info. But I can't help be more verbose. Think of a debugger. A tree of structs. Each struct has member data. We have a snapshot of this member data over time and a slider to scrub through it. The leaf node has an array of data that we wish to drive it's value. But we don't want to see that as a folder.
      for example:
      struct Foo
           int var;
      Foo foo;
      foo.var = 1;
      foo.var = 2;
      on frame 1 would display as
      (+) foo Foo
        |-  var   int   1
      not
      (+) foo Foo
        (+)  var   int   1
          |- 1
          |- 2
      I have a custom item renderer for the value field that is driven by the array. That works fine. But I can't suppress the folder icon ( and expandability ).
      Ideas?
        • 1. Re: ADG - How to suppress some folders?
          =VA=FyreHeart Level 2
          What you're trying to do is deceptively simple. Just remove the columns from the group.
          For example, the MXML for your
          (+) Foo
               (+) foo
                    |- var 1
          structure would look something like this:
          <mx:GroupingField name="Foo">
               <mx:summaries>
                    <mx:SummaryRow summaryPlacement="group">
                         <mx:fields>
                              <mx:SummaryField label="Foo" dataField="Foo" operation="SUM"/>
                              <mx:SummaryField label="var1" dataField="var1" operation="SUM"/>
                         </mx:fields>
                    </mx:SummaryRow>
               </mx:summaries>
          </mx:GroupingField>
          <mx:columns>
               <mx:AdvancedDataGridColumn headerText="Foo" dataField="Foo" width="100"/>
               <mx:AdvancedDataGridColumn headerText="var" dataField="var1" width="100"/>
          </mx:columns>
          To get rid of it, simply do this to your mx:columns array:
          <mx:columns>
          </mx:columns>
