3 Replies Latest reply on Feb 25, 2010 12:00 AM by eddjcaine
    n00b question - XML import woes
    eddjcaine
      Hey All,
      Am fairly new to Flex - having trouble getting my head round XML imports using HTTPRequest - have the following code:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" backgroundAlpha="0"
      initialize = "playlist.send()">
      <mx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      import mx.rpc.events.ResultEvent;
      [Bindable]
      private var plist:ArrayCollection;
      private function resultHandler(event:ResultEvent) :void {
      plist = event.result.playlist.tracklist;
      </mx:Script>
      <mx:HBox paddingBottom="10" paddingTop="10" paddingLeft="10" paddingRight="10" horizontalGap="20">
      <mx:Image/>
      </mx:HBox>
      <mx:HTTPService id="playlist" url="playlist.xml" result="resultHandler(event)"/>
      <mx:DataGrid dataProvider="{plist}" width="100%" height="100%" />
      </mx:Application>
      for some reason, although when debugging with breakpoint at end of resultHandler() the event seems to indicate that the XML file was imported, plist remains stubbornly set to null - any ideas why?
      thanks
      edd
        • 1. Re: n00b question - XML import woes
          saisri2k2 Level 4
          For the httpService add an parameter resultFormat as e4x (that would return yu xml in good format). Make the plist as public for u to be save.
          if 'playlist' is the root element of the XML then remove that from the following line
          make it to
          plist = event.result.tracklist;
          Hope it should help
          • 2. Re: n00b question - XML import woes
            Vikram_S Level 2
            Will you try this?
            plist = new ArrayCollection(mx.utils.ArrayUtil.toArray(event.result.playlist.tracklist));
            please update me it is correct or not?
            Vikram
            • 3. Re: n00b question - XML import woes
              eddjcaine Level 1
              Hey guys,
              Thanks for the answers - actually the problem was a little more simple than that - here is my XML data:
              <playlist version="1" xmlns="http://xspf.org/ns/0/">
                   <title>Edward Caine Pieces</title>
                   <info></info>
                   <annotation></annotation>
                   <trackList>
                        <track>
                             <creator>Tous les matin du monde</creator>
                             <title>Ossian Ensemble, Late Music Concert Series, 7/11/09</title>
                             <location>/mp3s/matin.mp3</location>
                             <image>images/ossia.jpg</image>
                             <info></info>
                             <album>Late Music Concert Series 09</album>
                        </track>
                   </trackList>
              </playlist>
              As you can see - I mis-spelled "trackList" (it has a capital L) - doh! rookie mistake!
              All sorted now - many thanks guys!
              Edd
