0 Replies Latest reply on Feb 24, 2010 4:09 PM by Jason Szeto
    [svn:fx-4.x] 14403: VideoPlayer mirroring bug fix
    Jason Szeto Level 3
      Revision: 14403
      Revision: 14403
      Author:   jszeto@adobe.com
      Date:     2010-02-24 16:09:21 -0800 (Wed, 24 Feb 2010)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-25471 - Spark VideoPlayer control shouldn?\226?\128?\153t reverse control buttons when changing layoutDirection
      VideoPlayer should not mirror, so I set layoutDirection = ltr in the CSS type selector. Fixed a bug where the VideoPlayer is mirrored when it goes full screen. Added logic to UIComponent to invalidate the layoutDirection if the parent has been changed.
      Set layoutDirection = ltr on the play button and volume bar so that they don't get reversed if layoutDirection = rtl on the VideoPlayer.
      QE notes: none
      Doc notes: none
      Bugs: SDK-25471
      Reviewer: Hans
      Tests run: checkintests
      Is noteworthy for integration: no
      Ticket Links:
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/branches/4.x/frameworks/projects/spark/defaults.css
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/skins/spark/VideoPlayerSkin.mxm l
