2 Replies Latest reply on Mar 3, 2010 4:07 AM by David_F57
    ClipEnableScrolling default
    David_F57 Level 5
      In responding to an earlier thread it raised a questiion I continually think about but never get around to raising. With panels quite often I will work beyond the display size of the panel (i.e. place some object in the panel then reduce its size) expanding and collapsing is also something that falls into the same category.  Clipenable is defaulting to false, so if a panel size is reduced programmatically objects fall outside the panels boundaries. Maybe clipenabled should default to true unless this is a profiling/performance type default.
