2 Replies Latest reply on Feb 25, 2010 9:35 AM by archemedia
    ArrayCollection - Summing values
    mfriasv Level 1
      Hello,
      In my app an ArrayCollection returns values like "1", "2", "3" and so on. Now, I would like to sum up 10 to each one so that the end result would be "10", "20", "30".
      How can I do that. I tried to find a way to convert them to numbers but I don't know if that' possible.
      Manolo
        • 1. Re: ArrayCollection - Summing values
          Gregory Lafrance Level 6
          This answers your question:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
            creationComplete="init();">
            <mx:Script>
              <![CDATA[
                import mx.collections.ArrayCollection;
                private var ac:ArrayCollection = new ArrayCollection(["1", "2", "3", "4", "5", "6", "7"]);
                [Bindable] private var ac2:ArrayCollection = new ArrayCollection();
                private function init():void{
                  for each(var str:String in ac){
                    ac2.addItem(Number(str) * 10);
            </mx:Script>
            <mx:ComboBox dataProvider="{ac2}"
              rowCount="{ac2.length}"/>
          </mx:Application>
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          www.ChikaraDev.com
          Flex / AIR Development, Training, and Support Services
          • 2. Re: ArrayCollection - Summing values
            archemedia Level 4
            The answer of Greg is correct. Also, look at the special Array functions which are very powerful:
            I converted the base array to numbers for convenience
            private var ac:ArrayCollection = new ArrayCollection([1, 2, 3, 4, 5, 6, 7]);
            And then:
            private function addToCollection(amt:int):void
                 ac.source.forEach(function callback(item:*, index:int, array:Array):void
                           item += amt;
                 ac.refresh();
            Dany
