0 Replies Latest reply on Feb 25, 2010 9:59 AM by Carol L. Frampton
    [svn:fx-trunk] 14421: Merge from 4.x mirroring PARB changes 14331, 14337, 14338.
    Carol L. Frampton Level 2
      Revision: 14421
      Revision: 14421
      Author:   cframpto@adobe.com
      Date:     2010-02-25 09:58:57 -0800 (Thu, 25 Feb 2010)
      Log Message:
      Merge 14401 to fix clipping issue for right-aligned RichEditableText which had x < 0.
      Merge 14402 to fix textAlignment issues for text with direction="rtl" for UIFTETextField and UITextField.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IVisualElement.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextField.as
          flex/sdk/trunk/frameworks/projects/spark/src/mx/core/FTETextField.as
          flex/sdk/trunk/frameworks/projects/spark/src/mx/core/UIFTETextField.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/RichEditable TextContainerManager.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
      Property Changed:
          flex/sdk/trunk/
