2 Replies Latest reply on Feb 26, 2010 2:48 AM by Peter Kahrel
    How Do I create a GREP Expression to Delete Leading Zero's
    Stancaines Level 1
      Hello, I Have a text document that I need to Change The files i have look  like this.
      220080007      01      01000000320COMPANY           NAME NAME                    004095521
      There are over a hundred thousand records similar to this. The Problem is I Need GREP Expression to change the last field (004095521)
      to ($4095521).
      Also after that That I would like to ad Decimal points to the numbers Ex. ($40955.21)
      Also note that in some of the records the last field also has 1, and sometimes 3 or 4 zeroes example (000409155) (014095523) (000095523)
      However the characters is always 9.
      Am using indesign CS3
      Please Help
      Thank you.
        • 1. Re: How Do I create a GREP Expression to Delete Leading Zero's
          Shonkyin Level 3
          As you say characters is always 9 and it stand in last of your paragraph?
          If your digit stand last in your paragraph then try below code:
          var myDoc =  app.activeDocument;
          app.changeGrepPreferences = NothingEnum.nothing;
          app.findGrepPreferences = NothingEnum.nothing;
          app.findGrepPreferences.findWhat = '\\d+$';
          app.findGrepPreferences.appliedParagraphStyle = 'insert your paragraph style';//insert your paragraph style applied on digits
          app.findGrepPreferences.appliedCharacterStyle = 'insert your character style';//insert your character style applied on digits or remove this line if no character style applied
          var myFound = myDoc.findGrep();
          for (a=myFound.length-1; a>=0; a--)
          myFound[a].contents = "($" + myFound[a].contents + ")."
          Shonky
          • 2. Re: How Do I create a GREP Expression to Delete Leading Zero's
            Peter Kahrel Adobe Community Professional & MVP
            You don't need a script for this. You can remove the leading zeroes and add the decimal points in one expression. In the Find/Change dialog, GREP tab, do this:
            Find what: (?<=\s)0*(\d+)(\d\d)$
            Change to: $$1.$2
            i.e "find a space followed by any zeroes, followed by any digits (capture these) followed by two digits (capture these too) at the end of a paragraph ($). Replace these with a dollar sign followed by the first capture, a decimal point, and the second capture.
            Peter
