0 Replies Latest reply on Feb 25, 2010 3:27 PM by kevinklin
    [svn:fx-trunk] 14440: Merge revision 14439 from 4.x to trunk.
    kevinklin Adobe Employee
      Revision: 14440
      Revision: 14440
      Author:   klin@adobe.com
      Date:     2010-02-25 15:27:30 -0800 (Thu, 25 Feb 2010)
      Log Message:
      Fix for http://bugs.adobe.com/jira/browse/SDK-25644. For the bug, I added some logic in the addedHandler to only call validateTransformMatrix when layoutDirection changes.
      Also, I refactored validateTransformMatrix() to make use of a backing variable for scaleX. This ensures that we have the correct sign on scaleX when the icon is resized when mirroring or going from mirrored to unmirrored. The backing variable is also updated during resizing because scaleX will change when the bitmap is resized.
      QE notes: None
      Doc notes: None
      Bugs: SDK-25644
      Reviewed By: Jason, Carol, Hans
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/FlexBitmap.as
      Property Changed:
          flex/sdk/trunk/
