2 Replies Latest reply on Feb 25, 2010 9:02 PM by Shonkyin
    Inserting an image after findGrep
    frameexpert Level 4
      Hello All,
      I have a some square-bracked text in my document. Inside each set of square brackets is the name of an EPS file that I want to insert inline at that location. So, for example:
      This is a test for inline images.[Image1.eps] This is where the image will go. Insert [Image2.eps]
      I am using this to locate the "tags":
      var oDoc = app.activeDocument;
      app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.NOTHING;
      app.findGrepPreferences.findWhat = "\\[([\\w]+\\.eps)\\]";
      app.changeGrepPreferences.changeTo = "";
      var oText = oDoc.findGrep(true);
      Now that I have an array of text objects in oText, I need to know how to get the location at the end of each one, so I can place the image after the "]" character. After I place the images, I will delete the bracketed text.
      So, my basic question is, given an item in oText, how do I get the location at the end of it? Thank you very much.
      Rick Quatro
        • 1. Re: Inserting an image after findGrep
          Mac_06 Level 2
          Have you tried Kasyan nice script?? If not please try
          http://www.kasyan.ho.com.ua/place_images.html
          Mac
          • 2. Re: Inserting an image after findGrep
            Shonkyin Level 3
            Below script comes with indesign_cs4_scripting_guide_scripts. It will also help you.
            //ReplaceTextWithGraphic.jsx
            //An InDesign CS4 JavaScript
            //Replaces each instance of a string with a specified graphic file.
            main();
            function main(){
                      mySetup();
                      mySnippet();
                      myTeardown();
            function mySetup(){
                 //Create an example document.
                 var myDocument = app.documents.add();
                 myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
                 myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
                 //Create a text frame on page 1.
                 var myTextFrame = myDocument.pages.item(0).textFrames.add();
                 //Set the bounds of the text frame.
                 myTextFrame.geometricBounds = myGetBounds(myDocument, myDocument.pages.item(0));
                 //Fill the text frame with placeholder text.
                 var myString = "This is an example paragraph.\r<graphic: \/c\/test.tif>\rThis is a paragraph following an inline graphic.\r<graphic: \/c\/test.tif>\rThis is another paragraph.";
                 myTextFrame.contents = myString;
            function mySnippet(){
                 //<fragment>
                 var myInlineGraphic, myX1, myY1, myX2, myY2, myFoundItem;
                 var myRegExp = "(?i)<graphic\\:\\s?(.*)\\s?>"
                 var myDocument = app.documents.item(0);
                 //Clear the grep find/change preferences.
                 app.findGrepPreferences = NothingEnum.nothing;
                 app.changeGrepPreferences = NothingEnum.nothing;
                 app.findGrepPreferences.findWhat = myRegExp;
                 //Search the document.
                 var myFoundItems = myDocument.findGrep(true);
                 //Clear the find/change preferences after the search.
                 if(myFoundItems.length != 0){
                      for(var myCounter = 0; myCounter < myFoundItems.length; myCounter ++){
                           //A potential problem comes up here: what if the graphic is too big
                           //to fit on the page? What if the text is overset? There are no
                           //foolproof solutions that can handle all of the possible problems
                           //that can arise; your best bet is to adjust your scripts to deal
                           //with the specific layouts of specific documents rather than to try to
                           //create a single function that can handle all situations for all
                           //possible documents.
                           //In this case, we simply make the frame a set size and place the graphic
                           //into the frame, then fit the graphic to the frame proportionally, and
                           //then fit the frame to the resized graphic.
                           myFoundItem = myFoundItems[myCounter];
                           myX1 = myFoundItem.characters.item(0).horizontalOffset;
                           myY1 = myFoundItem.characters.item(0).baseline;
                           myX2 = myX1 + 72;
                           myY2 = myY1 + 72;
                           myFileName = myFoundItem.contents.replace(/<graphic\:\s(.*)\s?>/i, "$1");
                           myFrame = myFoundItem.insertionPoints.item(0).rectangles.add();
                           //Recompose the text after adding the inline frame.
                           myFoundItem.parent.recompose();
                           myFrame.geometricBounds = [myY1, myX1, myY2, myX2];
                           try{
                                myInlineGraphic = myFrame.place(File(myFileName))[0];
                                myFrame.fit(FitOptions.proportionally);
                                myFrame.fit(FitOptions.frameToContent);
                           } catch(myError){}
                 //Now replace the tags.
                 myDocument.changeGrep();
                 //</fragment>
            function myTeardown(){
            function myGetBounds(myDocument, myPage){
                 var myPageWidth = myDocument.documentPreferences.pageWidth;
                 var myPageHeight = myDocument.documentPreferences.pageHeight
                 if(myPage.side == PageSideOptions.leftHand){
                      var myX2 = myPage.marginPreferences.left;
                      var myX1 = myPage.marginPreferences.right;
                 else{
                      var myX1 = myPage.marginPreferences.left;
                      var myX2 = myPage.marginPreferences.right;
                 var myY1 = myPage.marginPreferences.top;
                 var myX2 = myPageWidth - myX2;
                 var myY2 = myPageHeight - myPage.marginPreferences.bottom;
                 return [myY1, myX1, myY2, myX2];
            Shonky
