1 Reply Latest reply on Feb 26, 2010 6:46 AM by ecchuckles
    confused about lcds/fiber push refreshing on bindable results
    ecchuckles
      good day,
      I've got this class that uses lcds to query a clob in an oracle db we're using lcds & fiber with rtmp to push changes to all the clients and then display the changes to screen.  I can see the pushed updated data coming in to clients (with trace turned on in the debugger)  and the ourMl/lastResult shows the updated record but the propertychange (on the [bindable] ) or the changewatcher events don't seem to be firing.  what am I doing wrong?
      I've tried a bunch of different things here is the current code:
      package our.funcs
          import hut.Ourml;
          import hut.OurmlService;
          import flash.events.Event;
          import flash.events.TimerEvent;
          import flash.utils.Timer;
          import mx.binding.utils.ChangeWatcher;
          import mx.collections.ArrayCollection;
          import mx.controls.Alert;
          import mx.rpc.CallResponder;
          import mx.rpc.events.FaultEvent;
          import mx.rpc.events.ResultEvent;
          import org.osmf.events.TimeEvent;
          ///  standard class to work with ourml stored in the db
          public class wrOURML
              [Bindable]
              public var _ourml:Ourml;
              // setup up own responder & service
              private    var getOc:OurmlService = new OurmlService();
              private    var cal:CallResponder = new CallResponder();
              private var callBack:Function; // set up the caller to point to this record when query completes
              private var  octype:String;
              private var _asXML:XML; // this is the xml being changed...
              //[Bindable]
              public var asString:String;
              private var inited:Boolean = false;
              public function wrOURML(OURType:String, callFunc:Function)
                  trace("wrOURML called for " +OURType);
                  if (OURType == null || OURType.length == 0)  {
                      return ;
                  // setup for db call
                  // put on responders not the service
                  //cal.addEventListener(ResultEvent.RESULT, gotResp, false,0,false);
                  //cal.addEventListener(FaultEvent.FAULT, gotError, false,0,false);
                  cal.addEventListener(ResultEvent.RESULT, gotResp);
                  cal.addEventListener(FaultEvent.FAULT, gotError);
                  cal.token = getOc.getByOurtype(OURType);
                  callBack = callFunc; // remember the params
                  octype = OURType;
              private function ocChanged(e:Event) : void {
                  trace("ourml changed called");
              private function calChanged(e:Event) : void {
                  trace("cal changed called");
              private function updResp(event:ResultEvent) :void  {
                  trace("update result called");
              private function gotResp(event:ResultEvent) :void {
                  trace("wrOURML got resp called for " +octype + " event = " + event.result.toString());
                  if (cal.lastResult != undefined && (cal.lastResult as ArrayCollection).length > 0) {
                   _ourml = ((cal.lastResult)[0]) as Ourml;
                  trace("wrOURML  resp for " +octype + " is " + _ourml.ourtype);
                  ChangeWatcher.watch(this,"_ourml",ocChanged);
                  ChangeWatcher.watch(cal,"lastResult",calChanged);
                  //cal.removeEventListener(ResultEvent.RESULT,gotResp);
                  //cal.addEventListener(ResultEvent.RESULT,updResp);
                  else {
                      // set up as initial record
                      trace("wrOURML creating new record " +octype);
                      _ourml = new Ourml();
                      _ourml.ourtype = octype;
                      _ourml.our = "<"+octype+"/>";
                  _asXML =  new XML(_ourml.our); // convert for users and use this for changes
                  asString = _ourml.our;
                  if (!inited) { // updates pass through here ...
                      inited = true;
                      callBack(_asXML); // now set up who is interested
              /// run all upudates through here
              public function save() : void {
                  trace("wrOURML save called");
                  _ourml.our = _asXML.toXMLString(); // fold it back into a string
                   asString = _asXML.toXMLString(); // fold it back into a string
                  if ( _ourml.id > 0) // is it an update or new record
                        getOc.updateOurml(_ourml);
                  else
                        getOc.createOurml(_ourml);
              // TODO handle error
              private function gotError(event:FaultEvent) :void {
                  trace("Query failed");
              // let the outside see these...
              public function get ourml () :Ourml {
                  return _ourml;
              public function set ourml ( value:Ourml) : void {
                  _ourml = value;
              public function get asXML () :XML {
                  return _asXML;
              public function set asXML ( value:XML) : void {
                  _asXML = value;
