5 Replies Latest reply on Feb 26, 2010 8:12 AM by kglad
    Capture the true FPS
    DazFaz Level 1
      Hello everyone,
      Now no doubt this has been a problem for a few people and I have trawled through a few web pages to try and find a solution. Is there a way of capturing the true running frames per second when a flash movie is playing?
      That’s it really.
      Thanks for all your help in advance.
        • 1. Re: Capture the true FPS
          this.onEnterFrame = function(){
          yourtextfield.text=1000/(getTimer()-startTime);
          startTime=getTimer();
          • 2. Re: Capture the true FPS
            DazFaz Level 1
            Hi kglad,
            Thank you for your reponse.
            So to recap on your suggestion then:
            1000; Im assuming here that this figure equates to 1 second in time terms
            getTimer(); This will return the amount of milliseconds that the flash player has been running for
            startTime; again this will return the time in milliseconds the flash player has been running for at that set point in time (second pass).
            So in short:
                 timeItsTakenToCallThisFunctionAgain = getTimer()-startTime
                 framePerSecond = 1000/timeItsTakenToCallThisFunctionAgain
                 startTime = getTimer();
            This is leading somewhere becuase this calculation is not consistant when tested through the likes of MachBlue.
            • 3. Re: Capture the true FPS
              you wouldn't expect it to be consistant unless there's no change is system resources while that code is executing.  otherwise it shouldn't vary by more than 1 fps.
              you can use Math.round() to eliminate fractional changes in the fps if that suits your needs.
              p.s.  please mark this thread as answered, if you can.
              • 4. Re: Capture the true FPS
                DazFaz Level 1
                Whilst testing a very similar script on an embedded system the detected frame rate, on a number or occasions jump up to 500+fps. Strange I know but this is why I’m asking the question about true frames per second.
                • 5. Re: Capture the true FPS
                  you're doing something wrong.
                  use exactly the code i gave (except you can rename the textfield).
