3 Replies Latest reply on Feb 26, 2010 12:09 PM by kglad
    Autoplay Video Start at Specified Point
    seansks
      Hi, I'm hoping someone can assist me in making a change to my Actions. Basically the code below has been designed so that a video starts at 52 seconds (rather than the beginning) when you press play. It works good right now, starts where it's supposed to, but I want to change the code so that it autoplays the video starting at 52 seconds. The problem with this though, is that when I try and set it for autoplay, the video starts at the beginning and doesn't wait for it to load to 52 seconds before it autoplays. Any input on the coding? I need it just so that the autoplay doesn't kick in until the video is loaded to the 52 second point. Thank you in advance! Beyond appreciated!
      import fl.video.MetadataEvent;
      import fl.video.VideoProgressEvent;
      import fl.video.*;
      my_FLVPlybk.addEventListener(VideoEvent.COMPLETE, rewind);
      function rewind(eventObject:VideoEvent):void {
          my_FLVPlybk.seek(52);
          my_FLVPlybk.play();
      var fp:FLVPlayback = my_FLVPlybk;
      fp.addEventListener(VideoProgressEvent.PROGRESS, videoProgressHandler, false, 0, true);
      fp.addEventListener(MetadataEvent.METADATA_RECEIVED, metaDataHandler, false, 0, true);
      fp.autoPlay = true;
      var startSeekTime:Number = 52;
      var videoDuration:Number;
      var videoSeeked:Boolean = false;
      function metaDataHandler(event:MetadataEvent):void {
           if(event.info.duration != null){
                videoDuration =event.info.duration;
      function videoProgressHandler(event:VideoProgressEvent):void {
           var fp:FLVPlayback = event.currentTarget as FLVPlayback;
           var bytesLoaded:Number = event.bytesLoaded;
           var bytesTotal:Number = event.bytesTotal;
           if( !isNaN(videoDuration)){
                if( (bytesLoaded/bytesTotal) >= ( (startSeekTime+4)/videoDuration) && !videoSeeked ){
                     videoSeeked = true;
                     fp.seek(startSeekTime);
        • 1. Re: Autoplay Video Start at Specified Point
          disable autoPlay and, when loading is complete, execute your seek() method and then your play() method.
          • 2. Re: Autoplay Video Start at Specified Point
            seansks Level 1
            Would there be a way for you to paste my code with the edits i would need to do?
            Not sure exactly what to do to execute the seek() method and then the play() method.
            • 3. Re: Autoplay Video Start at Specified Point
              use:
              import fl.video.*;
                  my_FLVPlybk.play();
              fp.autoPlay = false;
                             videoSeeked = true;
              fp.play();
