3 Replies Latest reply on Mar 2, 2010 10:44 PM by Radhakrishna Bhat
    WSDL Wizard w/ SOAP, RequestContext, ComplexType and WSSE
    ClayMitchell
      Is it possible to run the wizard against a WSDL that uses a Request Context, SOAP, WSSE security and required input as a complexType?
      I've tried it and while it generated all the service and value objects, any time I try invoking the service, I get the following error:
      Array of input arguments did not contain a required parameter at position 1
      I don't even think the document is being sent to the server.
      I've read that in FB3, the wizard didn't handle SOAP services right and would ignore headers - I'm just trying to establish if it works at all and if I should continue trying to sort this out.
      The request document should look something like this:
      <soapenv:Envelope
          xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
         <soapenv:Header>
            <wsse:Security
                xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"
                xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
                xmlns:xsd="http://www.w3.org/2001/XMLSchema"
                xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd">
               <wsse:UsernameToken>
                  <wsse:Username>12345</wsse:Username>
                  <wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordText">12345</wsse:Password>
               </wsse:UsernameToken>
            </wsse:Security>
            <rc:RequestContext
                xmlns:rc="http://www.mydomain.com/crme/request-context.xsd">
               <rc:Property rc:key="username">12345</rc:Property>
               <rc:Property rc:key="sourceapp">12345</rc:Property>
            </rc:RequestContext>
         </soapenv:Header>
         <soapenv:Body>
            <s0:getAssociatePortfolioByNBID
                xmlns:s0="http://www.mydomain.com/wsdl/gpbs/associatePortfolio/AssociatePortfolioService/v001"
                xmlns:xsd="http://www.w3.org/2001/XMLSchema">
               <s0:nbid>NBD2ZXN</s0:nbid>
               <s0:attributeGroup>PARTYID</s0:attributeGroup>
            </s0:getAssociatePortfolioByNBID>
         </soapenv:Body>
      </soapenv:Envelope>
      Thanks!
        • 1. Re: WSDL Wizard w/ SOAP, RequestContext, ComplexType and WSSE
          MartinRose
          I was running into similar issues attempting to send a complex-typed request to a SOAP service.  Right up to the same error message, actually.  After a lot of googling and a little experimentation, I came up with an adjustment to the generated code that makes it work.
          (OBVersionDisclosure:  Flash Builder 4, Flex 4 SDK.)
          The generator produced an ActionScript class called [servicename], along with one named _Super_[servicename].  This service class gives you asynchronous RPC-style access to your SOAP methods.  For what we're doing, though, ignore the [servicename] class -- all the action is in the _Super_[servicename] class.
          Anyway, for each of these SOAP methods there is a same-named method on the Super class.  So if your SOAP method is named [mycall] and takes a data structure named [mycallstruct], it made an AS method that looks like this:
              public function [mycall]([mycallparam]:valueObjects.[mycallstruct]) : AsyncToken
                  model_internal::loadWSDLIfNecessary();
                  var _internal_operation:AbstractOperation = _serviceControl.getOperation("[mycall]");
                  var _internal_token:AsyncToken = _internal_operation.send([mycallparam]) ;
                  return _internal_token;
          Which should be fine, except that it's throwing that "did not contain a required parameter" fault.
          Long story short:  It looks like the send(args) form of the remote operation call is a little broken.  Because all I had to do to make this method work as advertised is this:
                  _internal_operation.arguments = [mycallparam];
                  var _internal_token:AsyncToken = _internal_operation.send() ;
          which is the call form I found in posted code for previous versions of Flex.
          Well, that's the extent of my knowledge on the subject.  Hope it's helpful.
          • 2. Re: WSDL Wizard w/ SOAP, RequestContext, ComplexType and WSSE
            Radhakrishna Bhat Level 3
            You need to add SOAP headers manually in your generated code.
            var header:SOAPHeader = new SOAPHeader(qname,"Security");
            header.content = <XML header>;
            <WebService_Instance>.addHeader(header);
            If your using FB4, add this code to servicename.as class's constructor. Replace <Webservice_instance> with _serviceControl
            Please refer to http://livedocs.adobe.com/flex/3/html/help.html?content=data_access_3.html
            -Radhakrishna
            • 3. Re: WSDL Wizard w/ SOAP, RequestContext, ComplexType and WSSE
              Hi MartinRose,
              If there are no parameters used in send() method, operation's 'arguments' value will be used. Either way it should successfully send the request parameter. Please file a bug at http://bugs.adobe.com/flex if you are facing any issue.
              -Radhakrishna
