0 Replies Latest reply on Feb 26, 2010 7:46 AM by smgilson
    [svn:fx-4.x] 14456: Adding ASDoc version tags classes
    smgilson Level 1
      Revision: 14456
      Revision: 14456
      Author:   smgilson@adobe.com
      Date:     2010-02-26 07:45:53 -0800 (Fri, 26 Feb 2010)
      Log Message:
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/automation/src/mx/automation/events/EventDetail s.as
          flex/sdk/branches/4.x/frameworks/projects/automation_air/src/mx/automation/air/AirDragMan agerAutomationHandler.as
          flex/sdk/branches/4.x/frameworks/projects/automation_air/src/mx/automation/air/AirFunctio nsHelper.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkApplicationAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkBorderContainerAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkButtonAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkButtonBarAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkButtonBarButtonAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkDataGroupAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkGroupAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkLabelAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkNavigatorContentAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkPanelAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkRadioButtonAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkSkinnableContainerAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkSpinnerAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkTabBarAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkTileGroupAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkTitleWindowAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkToggleButtonAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/SparkVideoPlayerAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/mediaClasses/SparkMuteButtonAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/supportClasses/SparkButtonBarBaseAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/supportClasses/SparkButtonBaseAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/supportClasses/SparkGroupBaseAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/supportClasses/SparkRangeAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/supportClasses/SparkSkinnableComponentAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/supportClasses/SparkSkinnableContainerBaseAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/supportClasses/SparkTextBaseAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/delegates /components/supportClasses/SparkTrackBaseAutomationImpl.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/events/Sp arkListItemSelectEvent.as
          flex/sdk/branches/4.x/frameworks/projects/automation_spark/src/spark/automation/events/Sp arkValueChangeAutomationEvent.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/accessibility/AccConst.as
          flex/sdk/branches/4.x/frameworks/projects/rpc/src/mx/rpc/soap/SOAPResult.as
