2 Replies Latest reply on Mar 2, 2010 12:39 PM by DavidMcDivitt
    additional string variable as input to process
    DavidMcDivitt
      I have a very simple web service print process that takes XML from the requester, combines with a statically defined XDP file, and produces PDF output. The server is called from a Classic ASP application. The web service works just fine, but I want to use it generically and have the requester provide the name of the template XDP file in addition to the XML. However many XDP templates will be placed on the server, and to use them the generic print process will be called providing the name of the template file and the XML to merge with it.
      I edited the XML request to include the additional variable. The XML response I got said "The input BLOB object should have attachmentID, remoteURL, or binaryData field specified". I tried two things. I tried including a remoteURL tag and putting a file on the Classic ASP server containing the template name. I then tried a binaryDatatag followed by a CDATA tag. Neither of these worked. The XML response says "xmldata: Content is not allowed in prolog., cause: Content is not allowed in prolog."
      I have no idea how to resolve this. If I remove the extra variable from the process and remove the extra variable from the supplied XML, I get back a URL to the created PDF on the LiveCycle server, which is what's supposed to happen. If I include an additional variable in the process and in the supplied XML, the XML is rejected.
      Presently I'm using a VBScript file for testing which is pasted below. Help would be appreciated. Thanks
      dim fs,writer,xml
      xml = "<soapenv:Envelope xmlns:soapenv=""http://schemas.xmlsoap.org/soap/envelope/"" xmlns:xsd=""http://www.w3.org/2001/XMLSchema"" xmlns:xsi=""http://www.w3.org/2001/XMLSchema-instance"">" & _
              "<soapenv:Body>" & _
                "<intf:invoke xmlns:intf=""http://adobe.com/idp/services?wsdl"">" & _
                  "<template_name>" & _
                    "<remoteURL>http://j11070:82/travel/test/TemplateName.ref</remoteURL>" & _
                  "</template_name>" & _
                  "<template_xml>" & _
                    "<remoteURL>http://j11070:82/travel/test/FY10_IN-STATE_LC_XSD.xml</remoteURL>" & _
                  "</template_xml>" & _
                "</intf:invoke>" & _
              "</soapenv:Body>" & _
            "</soapenv:Envelope>"
      set req = createobject("Microsoft.XMLHTTP")
      req.open "POST", "http://d97510:8080/soap/services/DHSIP01Travel", false
      req.setrequestheader "Content-Type", "application/soap+xml; charset=UTF-8"
      req.setrequestheader "SOAPAction","invoke"
      req.send xml
      set fs = createobject("Scripting.FileSystemObject")
      set writer = fs.createtextfile(".\009.xml",true)
      writer.Write req.responseText
      writer.close
      msgbox "done"
