3 Replies Latest reply on Mar 5, 2010 2:15 PM by olegkon
    Can't see Flex3 Container in AIR2 app
    olegkon Level 1
      This is probably a fairly basic question, but I started blending Flex3 & 4 code,
      and don't have much experience with writing my own Flex MXML components,
      so please bear with me.
      I am trying to move my AIR1.5 application into the Christophe Coentaets' embedded Tomcat AIR2 app as one of the Tabs:
      My old AIR1.5 App consisted of 1 MXML file with one screen (DataGrid), WebService, lots of AS3 code, total about 800 lines.
      There is also a Java Web service which I deploy on the embedded Tomcat.
      Since it's one screen, I would like to just put my app GUI on the tab of a final AIR2 app.
      So I removed Windowed app, tried to replace it with Component. FB4 gave me error saying that Component can't be here.
      Then I tried Container, and all code compiled.
      But when I try to run it, no Flex3 GUI shows up. I can see that it's initialized (Alert). Setting visible=true for that container didn't help.
      Am I doing something wrong ?  Should it be not Container but Component or something else like VBox?
      Here is a code snippet:
      Main app:
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
         title="AIR Application with Embedded Tomcat"
         height="600" width="800"
      <s:VerticalLayout paddingLeft="8" paddingRight="8" paddingBottom="8" paddingTop="8"/>
      </s:layout>   .....
      <mx:TabNavigator >
           <mx:VBox label="MyApp" paddingLeft="8" paddingRight="8" paddingBottom="8">
                <mx:HTML id="html" width="100%" height="100%"/>
                <local:AirXl7c visible="true" enabled="true"/>
      my component:
      <mx:Container xmlns:mx="http://www.adobe.com/2006/mxml"
      creationComplete="init()"  borderColor="#FCF9F9"
      Please help !
      Any doc describing how to blend Flex3 & 4 ?
      Or do I have to rewrite Flex3 into Flex4 code, not to blend it ?
        • 1. Re: Can't see Flex3 Container in AIR2 app
          John Hall Level 4
          Have you tried changing the halo namespace at the top to "mx" instead of "halo" at the end?
          • 2. Re: Can't see Flex3 Container in AIR2 app
            olegkon Level 1
            I changed my MXML component from Container to Canvas, that made my GUI visible.
            One other GUI problem I got is that
            when I change DataGrid data,
            in puts DataGrid on top of all other data fields
            thus coveringthem up.
            Setting   dataGrid.x=100   has no effect.
            That worked fine in Flex3 (DataGrid and other GUI components are in VBox),
            but broke while blending Flex4 with Flex3.
            In my component I have:
            So in main class it gets:
            Any advice ?
            • 3. Re: Can't see Flex3 Container in AIR2 app
              olegkon Level 1
              As I mentioned, when I reassingn a Datagrid's dataSource to a new collection (either populated from the data file or generated like rowCount, columnCount), it always places my DataGrid on top of other GUI components (top right corner).
              assigning   dataGrid.x=100 , dataGrid.bottom=10, dataGrid.verticalCenter=20  does not change anything, I think, because it is inside VBox.
              I checked what happened in pure Flex3 case, it was putting this DataGrid towards the bottom of the screen (even without any position-related assignments)
              So in Flex4 code I started putting that Component inside (Flex3) TabNavigator.
              That is the only difference I see.
              Any help is very appreciated !
