2 Replies Latest reply on Feb 26, 2010 1:13 PM by aurphir
    In flex charts the label for next month get dropped
    aurphir
      I found for DatatTimeAxis if you set disabledRanges to the last date of the month the label for next month gets dropped using property labelUnits='months". Any ideas? Below is the code:
      <?xml version="1.0"?>
      <!-- Simple example to demonstrate the DateTimeAxis class. -->
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
           <mx:Script>
                <![CDATA[
                     import mx.collections.ArrayCollection;
                     [Bindable]
                     public var stockDataAC:ArrayCollection=new ArrayCollection([{date: "2005, 6, 1",
                               close: 30}, {date: "2005, 7, 31", close: 25}, {date: "2005, 8, 3",
                               close: 40}, {date: "2005, 9, 4", close: 30}, {date: "2005, 10, 5",
                               close: 50}, {date: "2005, 11, 6", close: 43}]);
                     private var d:Date=new Date("7/31/2005");
                     [Bindable]
                     private var offDays:Array=[d];
                     public function myParseFunction(s:String):Date
                          // Get an array of Strings from the comma-separated String passed in.
                          var a:Array=s.split(",");
                          // Create the new Date object. Subtract one from
                          // the month property because months are zero-based in
                          // the Date constructor.
                          var newDate:Date=new Date(a[0], a[1] - 1, a[2]);
                          return newDate;
           </mx:Script>
           <mx:Panel title="DateTimeAxis Example"
                       height="100%"
                       width="100%">
                <mx:LineChart id="mychart"
                                 height="100%"
                                 width="100%"
                                 paddingRight="5"
                                 paddingLeft="5"
                                 showDataTips="true"
                                 dataProvider="{stockDataAC}">
                     <mx:horizontalAxis>
                          <mx:DateTimeAxis dataUnits="days"
                                               parseFunction="myParseFunction"
                                               disabledRanges="{offDays}"
                                               labelUnits="months"/>
                     </mx:horizontalAxis>
                     <mx:verticalAxis>
                          <mx:LinearAxis baseAtZero="false"/>
                     </mx:verticalAxis>
                     <mx:series>
                          <mx:LineSeries yField="close"
                                            xField="date"
                                            displayName="AAPL"/>
                     </mx:series>
                </mx:LineChart>
           </mx:Panel>
      </mx:Application>
        • 1. Re: In flex charts the label for next month get dropped
          Gregory Lafrance Level 6
          I found your posted code to be messed up. I fixed it and could not see your problem.
          Here is the fixed code.
               <mx:Script>
                    <![CDATA[
                         [Bindable]
                           {date: "2005, 6, 1", close: 30},
                           {date: "2005, 8, 3", close: 40},
                           {date: "2005, 10, 5", close: 50},
                         private var d:Date=new Date(2005,8,31);
                         [Bindable]
                              return newDate;
               </mx:Script>
                           height="100%"
                           width="100%">
                                     height="100%"
                                     width="100%"
                                     paddingRight="5"
                                     paddingLeft="5"
                                     showDataTips="true"
                         <mx:horizontalAxis>
                         <mx:verticalAxis>
                         </mx:verticalAxis>
                         <mx:series>
                                                xField="date"
                         </mx:series>
                    </mx:LineChart>
               </mx:Panel>
          </mx:Application>
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          www.ChikaraDev.com
          Flex / AIR Development, Training, and Support Services
          • 2. Re: In flex charts the label for next month get dropped
            aurphir Level 1
            Above code doesn't declare a valid date
