0 Replies Latest reply on Feb 26, 2010 1:36 PM by jamh51
    SOLVED: Dreamweaver CS3 crashes when clicking inside of a "for" or "foreach" loop
    jamh51
      I searched and searched for the answer to this and finally Adobe Support provided the relatively easy answer. I thought I would write a post here so that future searchers will find the answer.
      For months I've been having the problem where in a PHP file my Dreamweaver CS3 will crash when clicking inside of either a "for" or "foreach" loop. I had to use Notepad++ for those random files. I emailed support and received this answer, which did work:
        1. If Dreamweaver is open, quit the application.
        2. Delete the WinFileCache-AD76BB20.dat file from the Dreamweaver user configuration folder. Note that on Windows, the Application Data and AppData folders are hidden by default, so verify that your Windows Explorer folder options are set to View Hidden Folders.
        3. The location of this file is as follows:
          Dreamweaver CS3 on Windows Vista: C:\Users\[username]\AppData\Roaming\Adobe\Dreamweaver 9\Configuration
          Dreamweaver CS3 on Windows XP: C:\Documents and Settings\[username]\Application Data\Adobe\Dreamweaver 9\Configuration
        4. Restart Dreamweaver.
        This fixed the problem for me. Hope this helps.
        - Jamon
        Keywords: DW Dreamweaver CS3 crash click inside for foreach loop random files
