1 Reply Latest reply on Feb 26, 2010 5:11 PM by P.o.l.a.c.o
    CSS on Flex Effects?
    mchanggg
      I was wondering if I can extract the property of a Flex effects out to a CSS file.
      Is that possible?
      Mike
        • 1. Re: CSS on Flex Effects?
          P.o.l.a.c.o Level 1
          You mean something like the following?
          Create an MXML component called "GlowingImage" with this code:
          <mx:Image
          xmlns:mx="http://www.adobe.com/2006/mxml" rollOver="glowUp()" rollOut="glowDown()">
          <mx:Metadata>
          Style(name="glowColor",type="String",format="String",inherit="no")]
          </mx:Metadata>
          <mx:Script>
          <![CDATA[
          private var bStypePropChanged:Boolean = true;
          // Override the styleChanged() method to detect changes in your new style.
          override public function styleChanged(styleProp:String):void {
          super.styleChanged(styleProp);
          // Check to see if style changed.
          if (styleProp=="glowColor")
          bStypePropChanged=
          true;
          invalidateDisplayList();
          return;
          override protected function updateDisplayList(unscaledWidth:Number,
          unscaledHeight:Number):
          void {
          super.updateDisplayList(unscaledWidth, unscaledHeight);
          if (bStypePropChanged==true)
          // Redraw gradient fill only if style changed.
          glowEff.color = getStyle(
          "glowColor");
          bStypePropChanged=
          false;
          public function glowUp():void{
          if(!glowEff.isPlaying){
          glowEff.play([
          this],false);
          public function glowDown():void{
          if(glowEff.isPlaying){
          glowEff.reverse();
          else{
          glowEff.play([
          this],true);
          </mx:Script>
          <!-- Efecto rollover imgs -->
          <mx:Glow id="glowEff" alphaFrom="0.5" alphaTo="0.75" blurXFrom="0.0" blurXTo="10" blurYFrom="0" blurYTo="10" color="0x666666" target="{this}" duration="200"/>
          </mx:Image>
          Add the style component declaration in your css:
          GlowingImage
          glow-color:#FF0000;
          then declare the xmlns:cimg="the.placement.package.*" and use it like:
          <gimg:GlowingImage
          source="assets/alertaIcon.png" width="50" height="50"/>
          Does it solve the question?
