0 Replies Latest reply on Feb 26, 2010 4:32 PM by JohnMerlino
    imported catalyst project not exposing xml
    JohnMerlino Level 1
      Hey all,
      I tried to follow this catalyst tutorial: http://www.adobe.com/devnet/flashcatalyst/articles/building_datacentric_app_flas hcast_flashbuilder_03.html but as he is using ColdFusion, I am using an HTTP service type.
      When I run the flex application, I'm expecting to see 25 records from users table of my database in a list component, and all I see is 25 of this: [object User]
      Basically, what I did:
      1) Connect to data service (Http)
      2) Entered a url of xml data, method GET, operation of getAllItems
      3) search as name string as data type for the parameters of this operation
      4) users as service name (services.users as service package)
      5) test operation (authentication required) and clicked test, which showed the xml data
      6) Configure return type, selected User as root (not users), and clicked it for "is Array?" option
      7) Then selected the list component, checked "New Service Call", and for bind_to_field I checked "id" (not sure exactly what bind to field does)
      The following is the relevant stuff that was generated:
                  protected function list_creationCompleteHandler(event:FlexEvent):void
                  getAllItemsResult
      .token = users.getAllItems(/*Enter value(s) for */ search);
      <fx:Declarations>
      <s:CallResponder id="getAllItemsResult" />
      <users:Users id="users" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
      </fx:Declarations>
                  <s:List skinClass="components.DataList3" x="65" y="96" change="list_changeHandler()" id="list" creationComplete="list_creationCompleteHandler(event)" dataProvider="{getAllItemsResult.lastResult}" labelField="id">
      s:List>
      I do notice an error message that says "access of undefined property search". But again this was generated code so I have no idea where it was supposed to be defined. My main concern is that it's not showing records from the database (via the xml) but rather just showing: [object User]
      Thanks for any response.
