3 Replies Latest reply on Feb 27, 2010 5:53 AM by naval joshi
    connecting flex with php(wamp)
    naval joshi
      i m trying to connect a flex application to a php (wamp server)..bt i m unable to do soo
      ma application runs fine....bt wen i click submit button it shows ..transfering data frm localhost n nothing happens......database is nt updated........
      //flex code
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="send_data()">
      <mx:Script>
      <![CDATA[
      import mx.controls.DataGrid
      private function send_data():void {
      userRequest.send();
      </mx:Script>
      <mx:Label x="79" y="89" text="username"/>
      <mx:Label x="79" y="128" text="rolnumber"/>
      <mx:TextInput id="nm" x="153" y="87"/>
      <mx:TextInput x="153" y="126" id="roll"/>
      <mx:Button x="127" y="191" label="submit" id="sub" click="send_data()"/>
      <mx:HTTPService id="userRequest" url="http://localhost/connect.php" useProxy="false" method="POST">
      <mx:request xmlns="">
      <username>{nm.text}</username><rollnumber>{roll.text}</rollnumber>
      </mx:request>
      </mx:HTTPService>
      </mx:Application>
      //php code
      <?php
      mysql_connect("localhost", "root", "") or die("cannot connect");
      mysql_select_db("std_db") or die("cannot select database");
      $q="INSERT INTO `std_db`.`student` (`name` ,`roll`)VALUES ( '$_POST[nm]', $_POST[roll])";
      if(mysql_query($q))
      echo "sucessfully inserted";
      else
      echo" error occured";
      //if($row=mysql_fetch_array($result))
      //echo $row['
        • 1. Re: connecting flex with php(wamp)
          Matt Le Fevre Level 4
          //php code
          <?php
          if(mysql_query($q))
          else
          //echo $row['
          your query looks a little off, instead of
          try
              $name = mysql_real_escape_string($_POST["username"]);
              $roll =    mysql_real_escape_string($_POST["rollnumber"]);
              $q = "INSERT INTO student (name , roll) VALUES ('$name', '$roll')";
          • 2. Re: connecting flex with php(wamp)
            naval joshi Level 1
            thanx a lot it worked........wat shd be the code fr display full datbasee nnnnnnshd i usee the datagrid?
            • 3. Re: connecting flex with php(wamp)
              you can use a datagrid if you want, or a tile list, or a list, or an advanced datagrid, it's entirely up to you and what you plan to do with the data.
              The Full working basic code for what you're trying to do is this:
              Flex code:
                  <mx:Script>
                  <![CDATA[
                      import mx.rpc.events.ResultEvent;
                          userRequest.send();
                      private function handleResult(evt:ResultEvent):void
                          dg1.dataProvider = evt.result.player;
                  </mx:Script>
                  <mx:HTTPService id="userRequest" result="handleResult(event)" url="http://localhost/connect.php" useProxy="false" method="POST">
                      </mx:request>
                  </mx:HTTPService>
                  <mx:DataGrid id="dg1" x="69" y="261">
                      <mx:columns>
                          <mx:DataGridColumn headerText="Name" dataField="name"/>
                          <mx:DataGridColumn headerText="Roll" dataField="roll"/>
                      </mx:columns>
                  </mx:DataGrid>
              </mx:Application>
              PHP Code:
              <?php
                  if ($_POST["username"])
                      $query = "INSERT INTO student (name , roll) VALUES ('$name', '$roll')";
                      if(mysql_query($query))
                      else
                  $query="SELECT * FROM student";
                  $result = mysql_query($query);
                  $num_rows = mysql_numrows($result);
                  $i=0;
                  while ($i < $num_rows)
                      $getName = mysql_result($result,$i,"name");
                      $getRoll = mysql_result($result,$i,"roll");
                      print "<player><name>".$getName."</name><roll>".$getRoll."</roll></player>";
                      $i++;
