5 Replies Latest reply on Mar 1, 2010 10:45 AM by cheftimo
    Regarding - ComboBox
    venkatsyss Level 1
      hi,
      My question how to display the data base values in combo box.
      I have used httpservice  and the id is userRequest url is combox.php.In the combo.php i fetch the values from the database and returned it.
      My query is:
      <?php
      $con=mysql_connect("localhost","root","");
      if(!$con){
          echo "Error in Connecting Database";
      mysql_select_db("project",$con);
      $sql="select * from tbl_member";
      $result=mysql_query($sql);
      print"<users>";
      while($row=mysql_fetch_object($result)){
          print "<user>
          <userid>".$row->member_id."</userid>
          <username>".$row->member_fname."</username>
          </user>";
      print"</users>";
      In the Httpservice i have call a function in the result  method.In the function i have declare a array and assigned the values to the arrays.The follwoing code shows:
      ans=event.result.users.user;
      But the result to fails to display in the combo box.
      Here my code in the comboBox:
      <mx:HBox>
              <mx:Label text="DisplayName"></mx:Label>
              <mx:ComboBox id="empId" dataProvider="{ans}" >
              </mx:ComboBox>
          </mx:HBox>
      Answer shows in the browser is [object object]
      Please provide me the solution to solve the problem.
      Thanks and Regards,
      venkat.R
        • 1. Re: Regarding - ComboBox
          cheftimo Level 2
          I don't know PHP, but I gather your Htppservice is returning a query containing the usernames and IDs. If that is the case, try something like this (I am assuming ans is a bindable ArrayCollection):
          In your result handler,
          ans = event.result as ArrayCollection
          in your <mx:ComboBox>,
          labelField = "username"
          HTH,
          Carlos
          • 2. Re: Regarding - ComboBox
            venkatsyss Level 1
            hi,
            Thanks for you reply .i got it the answer in a  successful manner.
            Another question is,
            I have to display the username in the combo Box .If the  user is selected a username in the Combobox we can display all the text input and the value in the text input.
            I tried in the above manner but i could not able to get it.
            <mx:states>
                <mx:State name="eShow">
                    <mx:AddChild>
                        <mx:Panel>
                            <mx:TextInput id="temp">
                            </mx:TextInput>
                        </mx:Panel>
                    </mx:AddChild>
                </mx:State>
            </mx:states>
            //this function is have called in the combo box in the change mwthod.
            private function show(event:Event):void{
                        currentState="eShow";
                        temp.text=event.currentTarget.selectedItem.username;
            But i could not able to print the corresponding value in the textinput.
            Please find me the solutions to solve the problem.
            Thanks and Regards,
            venkat.R
            • 3. Re: Regarding - ComboBox
              cheftimo Level 2
              venkat:
              This should work in private function show():
              temp.text = "{empId.selectedItem.username}"
              Salud,
              Carlos
              • 4. Re: Regarding - ComboBox
                venkatsyss Level 1
                hi,
                Thanks for your kind reply.But  it fails to display the result in the corresponding textinput.
                Thanks and Regards,
                venkat.R
                • 5. Re: Regarding - ComboBox
                  cheftimo Level 2
                  venkat:
                  Is 'username' the correct name of the parameter?
                  Try this:
                  temp.text = "{empId.selectedItem}"
                  If that doesn't work either, show the code for the ComboBox, the show() function and how you are using that function.
                  Carlos
