5 Replies Latest reply on Mar 20, 2010 4:40 PM by Fredrik Borgström
    Newbie question concerning Flash Builder 4 / php / mysql / encode_utf8
    _boba fett_
      I've been following the "Tutorials for developing Data-centric Application with Flex 4" and could succesfully reproduce the Chapter 5-application (Paging with PHP).
      Now I want to alter this example with my own MySQL-database. But when I set some info in the Auto-detect Return Type (I mean the two integer parameters) I get an error message stating that I have to use encode_utf8.
      Can someone help me with this problem? I assume it's not that hard to get it right but I can't find it...
        • 1. Re: Newbie question concerning Flash Builder 4 / php / mysql / encode_utf8
          Radhakrishna Bhat Level 3
          Can you please share your MySQL sample database dump file and the PHP file you are using? There may be some specific database setting that is causing the issue.
          -Radhakrishna
          • 2. Re: Newbie question concerning Flash Builder 4 / php / mysql / encode_utf8
            _boba fett_ Level 1
            Radhakrishna
            When I run my tester-script (PHP) I can see the content of my table.
            Here's my PHP (PagingService.php):
            <?php
            * This sample service contains functions that illustrate typical service operations.
            * This code is for prototyping only.
            * Authenticate users before allowing them to call these methods.
            class PagingService {
                /* Connection variables */
                var $username = "*****";
                var $password = "*****";
                var $server = "localhost";
                var $port = "3306";
                var $databasename = "db_bib";
                var $tablename = "bib";
                var $connection;
                public function __construct() {
                    $this->connection = mysqli_connect($this->server, $this->username, $this->password, $this->databasename, $this->port);
                    $this->throwExceptionOnError($this->connection);
                public function count() {
                    $stmt = mysqli_prepare($this->connection, "SELECT COUNT(*) AS COUNT FROM $this->tablename");
                    $this->throwExceptionOnError();
                    mysqli_stmt_execute($stmt);
                    mysqli_stmt_bind_result($stmt, $rec_count);
                    mysqli_stmt_fetch($stmt);
                    mysqli_stmt_free_result($stmt);
                    return $rec_count;
                public function getItems_paged($startIndex, $numItems) {
                    $stmt = mysqli_prepare($this->connection, "SELECT bib_ID, bib_titel, bib_ondertitel, bib_uitgiftejaar FROM $this->tablename LIMIT ?, ?");
                    mysqli_bind_param($stmt, 'ii', $startIndex, $numItems);
                    $rows = array();
                    mysqli_stmt_bind_result($stmt, $row->bib_ID, $row->bib_titel, $row->bib_ondertitel, $row->bib_uitgiftejaar);
                    while (mysqli_stmt_fetch($stmt)) {
                        $rows[] = $row;
                        $row = new stdClass();
                    mysqli_close($this->connection);
                    return $rows;
                 * Utility to throw an exception if an error occurs
                 * while running a mysql command
                private function throwExceptionOnError($link = null) {
                    if($link == null) {
                        $link = $this->connection;
                    if(mysqli_error($link)) {
                        $msg = mysqli_errno($link) . ": " . mysqli_error($link);
                        throw new Exception('MySQL Error - ' . $msg);
            It seems to me that the script contains no error... but one never knows...
            I've also added a screenshot of the definition of the database:
            And a screenshot of the fields-definitions of table bib:
            Let me know when more info is needed!
            With kind regards
            • 3. Re: Newbie question concerning Flash Builder 4 / php / mysql / encode_utf8
              You have to execute query "set names utf8' in your PHP Class. Please refer the bug http://bugs.adobe.com/jira/browse/FB-24643
              -Radhakrishna
              • 4. Re: Newbie question concerning Flash Builder 4 / php / mysql / encode_utf8
                Fredrik Borgström
                Hi Boba Fett,
                I had the same error. This is how I made it work (my additions/changes marked in bold):
                function utf8_encode_array ($array) {
                     $retArray = Array ();
                     foreach($array as $key => $value) {
                          $retArray[$key] = utf8_encode ($value);
                     return $retArray;
                        $rows = array();
                            $encodedRow = utf8_encode_array ($row);
                            $rows[] = $encodedRow;
                        return $rows;
                Of course, you need to change every function in the same way. And if you only should return ONE item, then just use utf8_encode (item).
                Hope this helps.
                Fredrik Borgström
                Teambuilding Stockholm
                • 5. Re: Newbie question concerning Flash Builder 4 / php / mysql / encode_utf8
                  Fredrik Borgström Level 1
                  Noticed an error in my script in case the column names also contains UTF8 characters (which you might want). Then you have to change the function that I provided earlier to this (change in bold):
                             $retArray[utf8_encode ($key)] = utf8_encode ($value);
                       return $retArray;
                  /Fredrik
