8 Replies Latest reply on Mar 2, 2010 8:47 AM by MJ2516
    Rotating banner with multiple links?
    MJ2516 Level 1
      Beginner question~
      Is it possible to create a rotating banner with 3 or 4 links in Dreamweaver? I need to create a banner with automatically rotating images that each link to a different page. I don't know Flash. Is this possible to do in Dreamweaver?
      Thanks for any help.
        • 1. Re: Rotating banner with multiple links?
          Turnkeye
          You can create AJAX banner, all is needed is to copy and paste ready to use code.
          Here are detailed instructions and examples:
          http://www.sohtanaka.com/web-design/automatic-image-slider-w-css-jquery/
          Demo of the script is here: http://www.sohtanaka.com/web-design/examples/image-slider/
          All you need to place your content inside banner divs and include the banner JS to the html.
          http://turnkeye.com
          • 2. Re: Rotating banner with multiple links?
            ALsp Adobe Community Professional
            If you can wait about a week, we'll be releasing a fully automated image/banner rotator extension. Here is sneak peek:
            http://www.projectseven.com/products/galleries/irm/testing/sneak-peek/
            If you're not familiar with PVII, we are the oldest and one of the largest developers of commercial Dreamweaver extensions - having been at it since 1998.
            If you don't have a budget, jQuery is probably overkill and the example cited earlier is not what I would call a banner rotator - it's a horizontal slider or "carousel" as they are commonly called - sort of like one of the other widgets we produce:
            http://www.projectseven.com/products/tools/horizontal-glider/examples/headlines/index.htm
            In any event, jQuery is a good solution if you are willing and able to do a little custom coding yourself - and it is, of course, free. If you have a development budget, our tools cannot be beat.
            Good luck to you.
            Al Sparber - PVII
            Dreamweaver Menus | Galleries | Widgets
            http://www.projectseven.com/go/hgm
            The Ultimate Web 2.0 Carousel
            • 3. Re: Rotating banner with multiple links?
              MJ2516 Level 1
              Thank for your response.We have no budget (I work for anon-profit) and I
              can't code beyond basic HTML.
              M
              • 4. Re: Rotating banner with multiple links?
                MJ2516 Level 1
                Thanks for your response. The example you provided show a horizontal
                sliding image, which is not what I need. I need an image to slowly fade
                into another image on top of it.
                Do you have any other suggestions?
                Would there be somewhere I could get Flash code I could copy and paste?
                M
                • 5. Re: Rotating banner with multiple links?
                  John Waller Adobe Community Professional & MVP
                  jQuery requires no more than basic HTML. Give it a go.
                  • 6. Re: Rotating banner with multiple links?
                    Turnkeye Level 1
                    Here is another script with fade effect:
                    "A Simple jQuery Slideshow"
                    http://jonraasch.com/blog/a-simple-jquery-slideshow
                    You need to copy and paste the code, it is even better that flash (+ it is SEO freindly!)
                    Let us know if you need any help.
                    http://turnkeye.com
                    • 7. Re: Rotating banner with multiple links?
                      MJ2516 Level 1
                      Thanks for your help. Is it possible to link each image with a separate url?
                      http://turnkeye.com
                      • 8. Re: Rotating banner with multiple links- Please help!
                        MJ2516 Level 1
                        I created an html file with the banner images;
                        <div id="slideshow">
                        <img src="banner images/legis3.jpg" alt="" class="active" />
                        <img src="banner images/store_icon.jpg" alt="" />
                        <img src="banner images/tr_corner.jpg" alt="" />
                        </div>
                        I created a CSS file and applied it to the html. The images stacked on
                        top of each other- good;
                        @charset "utf-8";
                        /* CSS Document */
                        #slideshow {
                            position:relative;
                            height:157px;
                            width: 220;
                        #slideshow IMG {
                            position:absolute;
                            top:0;
                            left:0;
                            z-index:8;
                        #slideshow IMG.active {
                            z-index:10;
                        #slideshow IMG.last-active {
                            z-index:9;
                        I'm not sure what to do with the remaining jQuery code. I created a new
                        javascript file;
                        function slideSwitch() {
                            var $active = $('#slideshow IMG.active');
                            var $next = $active.next();
                            $next.addClass('active');
                            $active.removeClass('active');
                        $(function() {
                            setInterval( "slideSwitch()", 5000 );
                            $active.addClass('last-active');
                            $next.css({opacity: 0.0})
                                .addClass('active')
                                .animate({opacity: 1.0}, 1000, function() {
                                    $active.removeClass('active last-active');
                        $(function() {
                            if ( $active.length == 0 ) $active = $('#slideshow IMG:last');
                            var $next =  $active.next().length ? $active.next()
                                : $('#slideshow IMG:first');
                                .addClass('active')
                        $(function() {
                        I added a behavior to the HTML file. I added "Call Javascript" on load, and browsed to the javascript file in a desktop folder with all the other elements. The final HTML code was;
                        <link href="banner images/banner.css" rel="stylesheet" type="text/css">
                        function MM_callJS(jsStr) { //v2.0
                          return eval(jsStr)
                        </script>
                            <img src="banner images/wiseye_corner_legis3.jpg" alt="" class="active" onClick="MM_callJS('banner.js')" /><img src="banner images/DVD_store_icon.jpg" alt="" /><img src="banner images/wiseye_tr_corner_cpn2010.jpg" alt="" />
                        </div>
                        The preview doesn't rotate.
                        Can anyone tell me how to apply the jQuery code, and any correction to the code.
                        The final banner needs a separate link with each image.
                        Thanks for any and all help.
