0 Replies Latest reply on Feb 28, 2010 10:13 AM by Scott R. Hamilton
    LAST_INSERT_ID() delivers 0 as result
    Scott R. Hamilton Level 1
      I'm attemping to insert a record into a mySQL table and to get the primary key of the
      inserted record. According to the mySQL documentation using this query after the
      insert should give the auto incremented key of the inserted record:
      SELECT LAST_INSERT_ID() as LastId;
      This works fine in the SQL monitor in mySQL -  INSERT.. followed by
      SELECT LAST_INSERT... delivers the primary key of the just inserted
      record.
      When I execute the two queries from ActionScript, I get 0 as a result in
      event.result.records.record.LastId
      So the returned data structure has the element LastId added to it, as per
      my query but the value is not correct.
      Has anyone had and solved this issue in AS?
      Scott
