1. Re: FMS 3.5.0 stops streaming live pre-recorded streams unexpectedly
Asa - FMS Mar 1, 2010 10:55 AM (in response to Syberkitten)This does sound serious. Can you upgrade to fms 3.5.3 first, as we've fixed several related issues with deadlocks and stream stalls. It may instantly cure your problem.
http://www.adobe.com/support/flashmediaserver/downloads_updaters.html
Following that we'll probably take a bug to investigate.
2. Re: FMS 3.5.0 stops streaming live pre-recorded streams unexpectedly
Syberkitten Mar 2, 2010 1:06 AM (in response to Asa - FMS)thanks for the reply, we'll do the install and see if it helps..
3. Re: FMS 3.5.0 stops streaming live pre-recorded streams unexpectedly
Syberkitten Mar 10, 2010 1:48 AM (in response to Syberkitten)hi Again,
well, we've upgrade to 3.5.3 r824 on our virtual machine
and the problem still persists... (image freeze after a few minutes)
Yet I need to mention that our production system (using real hardware)
running FMS v3.5.2 r654 has no stalls or freezes, and braodcast can go on for days
uninterrupted.
since our testing system is running Virtual, i'd appreciate if you have any ideas
to solvethis inconvenience...
4. Re: FMS 3.5.0 stops streaming live pre-recorded streams unexpectedly
Asa - FMS Mar 10, 2010 6:28 PM (in response to Syberkitten)Hmm, well FMS has some troubles with living for the long haul on virtual machine environments and it usually comes back to how those VMs present their network. When the VM does bridged network for instance it's sharing time with the proper OS to get connection traffic for its applications. The unfortunate nature of that was that when we tested the performance for network sharing from an FMS out of a VM was so bad that it couldnt' be supported as a good configuration. Consequently we recommend to most deployments of 'don't do that'.
If it has to get solves and has to be a virtual machine, then I'd recommend playing with the various network modes to see if you can find one that's going to play happier with the server's 24/7 networking needs. It seems like the VM/FMS combo is the problem then that's where I'd be looking.
Asa
