3 Replies Latest reply on May 13, 2010 1:19 PM by VRPDeveloper
    FlexPMD Outline view not working - throwing an error
    AJ
      For some reason the FlexPMD is throwing error when I open FlexPMD Outline.
      My environment:
      Windows 7 64 bit
      Flex Builder 3.0.2 Standalone
      FlexPMD 1.0.1
      The error is:
      Error creating the view.
      org.eclipse.ui.IMemento.getBoolean(Ljava/lang/String;)Ljava/lang/Boolean;
      When I click OK, it shows the Outline Window but it displays Error creating the view. Here are the full details:
      java.lang.NoSuchMethodError: org.eclipse.ui.IMemento.getBoolean(Ljava/lang/String;)Ljava/lang/Boolean;
          at com.adobe.ac.pmd.eclipse.flexpmd.view.OutlineView.restoreState(OutlineView.java:235)
          at com.adobe.ac.pmd.eclipse.flexpmd.view.OutlineView.createPartControl(OutlineView.java:187)
          at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:370)
          at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:227)
          at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:592)
          at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:299)
          at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:531)
          at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:179 )
          at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFo lder.java:268)
          at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder .java:65)
          at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStack Presentation.java:400)
          at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1256)
          at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:668)
          at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:576)
          at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:564)
          at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:270)
          at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:931)
          at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2515)
          at org.eclipse.ui.internal.WorkbenchWindow$23.run(WorkbenchWindow.java:2837)
          at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
          at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:2818)
          at org.eclipse.ui.internal.WorkbenchWindow$17.runWithException(WorkbenchWindow.java:2135)
          at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
          at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
          at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:123)
          at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3659)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3296)
          at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:801)
          at org.eclipse.ui.internal.Workbench$25.runWithException(Workbench.java:1342)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2309)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
          at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:461)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java :112)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:169)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:106)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:76)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
          at java.lang.reflect.Method.invoke(Unknown Source)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:508)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
          at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
