2 Replies Latest reply on Mar 1, 2010 11:51 AM by Vejko
    Trimmed standard output using NativeProcess
    Vejko
      I would like to list all the USB devices connected to the machine (OSX snow leopard) and I am using NativeProcess in AIR 2.0.
      It works perfectly, but the result XML is trimmed. It looks I only get the first part of the standard output data.
      does anyone have an idea what can be the problem?
      This is my code:
      public function getUSBDevices():void
        var file:File = file.resolvePath("/usr/sbin/system_profiler");
        var args:Vector.<String> = new Vector.<String>;
        args.push("system_profiler");
        args.push("SPUSBDataType");
        args.push("-xml");
        var nativeProcessStartupInfo:NativeProcessStartupInfo = new NativeProcessStartupInfo();
        nativeProcessStartupInfo.arguments =  args;
        nativeProcessStartupInfo.executable = file;
        process = new NativeProcess();
        process.addEventListener(ProgressEvent.STANDARD_OUTPUT_DATA,        onOutputData)
        process.addEventListener(NativeProcessExitEvent.EXIT,                                 onExit);
        process.addEventListener(ProgressEvent.STANDARD_ERROR_DATA,          onIOError);
        process.addEventListener(IOErrorEvent.STANDARD_OUTPUT_IO_ERROR, onIOError);
        process.addEventListener(IOErrorEvent.STANDARD_ERROR_IO_ERROR,   onIOError);
        process.addEventListener(IOErrorEvent.STANDARD_INPUT_IO_ERROR,     onIOError);
        process.start(nativeProcessStartupInfo);
        public function onExit(e:NativeProcessExitEvent):void{
        textReceived.text = String(res);
        public function onOutputData(event:ProgressEvent):void {
        res = process.standardOutput.readUTFBytes(process.standardOutput.bytesAvailable);
      If I call system_profiler SPUSBDataType -xml through the OSX terminal I get a full XML result, but from my AIR app I only get the half of it.
      Thanks in advance,
          Zsolt
