0 Replies Latest reply on Mar 1, 2010 6:53 AM by SIEKAR
    Cannot expand an item in AdvancedDataGrid Programatically
    SIEKAR
      I am currently using an advanceddatagrid to display a list of documents that are Grouped by Document Name and I would like to expand  an item of this advanced datagrid programatically to select a document. For the moment my code for the performing the above mentioned task looks like:
      var openNodes:Object = IHierarchicalCollectionView(grid.dataProvider).openNodes;
           for each (var item:Object in openNodes){
                grid.selectedIndex++;
      // Select First Document
                for each(var doc:Document in item.children){
                     if(doc != selectedDocument)
      //Move Selected Index
                     else
                          break;
      This code has some error as it does not point to the correct document sometimes.. Can anyone suggest a better way to accomplish the same. I tried using expandItem and expandChildrenof methods in the Advandceddatagrid but it does not work. Even after giving a grid.validate() call to refresh the control the above two methods cannot expand the node I need.. Any help would be appreciated.
