3 Replies Latest reply on Sep 9, 2007 12:48 PM by kglad
    question about inserting long text into .htmlText
    baitwens Level 1
      Hi guys hope you can help me...
      I need to make a dynamic text field (scrollable) that contains text, images, MCs and links.
      I assigned to the text field the instance name textField_txt and attached this As code to the frame that's contains it:
      textField_txt.htmlText = "<p>Here's a movie clip symbol:<img src='symbol_ID'>";
      symbol_ID is a linkage that's been assigned to a MC in the library, that I want to load into my text field.
      So far so good, the problem comes when I change the example text "Here's a movie clip symbol:" with the text I have to use. I've tried different times to change it, to take off & and stuff that can mess things up, but it still giving me the same message when I pubblish the clip:
      String literal was not properly terminated�
      Syntax error.�
      I kinda figured out that this could be related to the text lenght, text seem to be too long, but I'm not sure. Anyone? Thanx in advance
