I'm using RH 8 HTML with output to WebHelp. I can't seem to get the tables in my snippets to stylize. I have an "invisible" style that I use when I'm just trying to layout lists or something else in an orderly manner and don't want any table structure to appear.
If I try to change the table style in the snippets, my styles aren't available. Similarly, if I manually try to take away the borders, after I hit "apply" the settings reset back to where they were before. I tried adding the "table class="invisible" tag in the code of the snippets, but that doesn't seem to be working either.
As it is, I'm using the tables to put two lists side-by-side, but you can see all the ugly table borders on publish.
Any suggestions?
Thanks!
Take a look at Snippets in http://www.grainge.org/pages/authoring/rh7/rh7.htm
