4 Replies Latest reply on May 27, 2010 7:44 AM by TanweerHq
    valueCommit not called for DropDownList
    JockMahon Level 1
      Is there any reason why the function is not been called, this works if the drop down is a dtagrid instead
               xmlns:mx="library://ns.adobe.com/flex/halo">
          <fx:Script>
              <![CDATA[
                  import mx.controls.Alert;
                  import mx.events.FlexEvent;
                  protected function supplierDopDown_valueCommitHandler(event:FlexEvent):void
                      Alert.show("Hitting here");
          </fx:Script>
          <fx:Declarations>
              <s:ArrayCollection id="g">
                  <fx:Object name="asd"/>
                  <fx:Object name="zxc"/>
                  <fx:Object name="qwe"/>
              </s:ArrayCollection>
          </fx:Declarations>
              <s:DropDownList id="supplierDopDown"
                              dataProvider="{g}"
                              valueCommit="supplierDopDown_valueCommitHandler(event)"
                              labelField="name"
                              width="127"
                              fontWeight="normal"/>
      </s:Application>
        • 1. Re: valueCommit not called for DropDownList
          Flex harUI Adobe Employee
          The rules on valueCommit were inconsistent in mx components.  Spark uses
          them more consistently but differently.  What action are you taking to try
          to get valueCommit to fire?  It should only fire for programmatic changes.
          • 2. Re: valueCommit not called for DropDownList
            JockMahon Level 1
            well in this example i expected it to trigger , as it does for ComboBox, when the componet is created and its dataprovider is set
            • 3. Re: valueCommit not called for DropDownList
              Lead.Bi
              I am seeing problems with programmatic change to fire valueCommit as well.. It works fine in Flex 3.
              Lead
              • 4. Re: valueCommit not called for DropDownList
                TanweerHq
                Try this code. Click on button after selecting value in Dropdownlist.
                    <fx:Script>
                        <![CDATA[
                                Alert.show("Yes Hitting here");
                    </fx:Script>
                    <fx:Declarations>
                    </fx:Declarations>
                                    dataProvider="{g}"
                                    labelField="name"
                                    width="127"
                                    fontWeight="normal" dropShadowVisible="true"/>
                    <s:Button x="247" y="247" label="Button" click="{g.addItem('New value' as Object)}"/>
                </s:Application>
