4 Replies Latest reply on Mar 4, 2014 9:09 AM by Aviral M. Sharma
    underline chars in a button label
    JockMahon Newcomer
      i used to do this in flash to under line a char in a button label to indicate its keyborad short cut
      addItemButton.labelPath.html      =  true;
      addItemButton.labelPath.htmlText     = "<u>A</u>dd Item";    //A
      how can i do this in flex
      thanks
        • 2. Re: underline chars in a button label
          Matt Le Fevre Champion
          it's not as simple as that i'm afraid, you'll have to create your own button component i think.
          luckily!!! it's already been done for you !!
          here's the link:
          http://cookbooks.adobe.com/post_Button_with_html_text-14186.html
          and an example i tried
          • 4. Re: underline chars in a button label
            Aviral M. Sharma
            The above link is dead (Adobe took it down)
            From web archive:
            http://web.archive.org/web/20120603010717/http://cookbooks.adobe.com/post_Button_with_html _text-14186.html
            (Alternate solution is
            http://stackoverflow.com/questions/828562/how-to-add-mnemonic-character-to-a-regular-butto n-in-flex-need-that-for-shortc)
            Below is code from cookbook's link (since web archive's link is redirects to 'not so useful' link = http://forums.adobe.com/index.jspa)
            Problem
            I am need to show html text in Flex Button control.
            Solution
            I developed HTMLButton control that has another property htmlLabel, When you specify HTML text in htmlLabel property, this control show label like as HTML text.
            Detailed explanation
            This is source code of HTMLButton control:
            package com.si.controls
            import flash.events.Event;
            import flash.text.TextLineMetrics;
            import mx.controls.Button;
            import mx.core.UITextField;
            import mx.core.mx_internal;
            use namespace mx_internal;
            * The HTMLButton class have additional property is htmlLabel.
            * You cas specify HTML text in htmlLabel property.
            public class HTMLButton extends Button
            *  @private
            *  Storage for the htmlText property.
            private var _htmlLabel:String;
            *  @private
            *  The value of the unscaledWidth parameter during the most recent
            *  call to updateDisplayList
            private var oldUnscaledWidth:Number;
            *  @private
            *  This flag indicate htmlText changed for this component
            private var htmlLabelChanged:Boolean;
            *  @private
            *  This flag indicate style changed for this component
            private var styleChangedFlag:Boolean = true;
            *  @private
            *  This flag indicate tooltip set for this component
            private var toolTipSet:Boolean = false;
            *  @private
            *  This label setter override for update htmlLabel property with null
            override public function set label(value:String):void
            super.label = value;
            if (super.label != value)
              _htmlLabel = null;
            override public function get label():String
            if(isHTML)
              return _htmlLabel;
            return super.label;
            [Bindable("htmlLabelChanged")]
            [CollapseWhiteSpace]
              [Inspectable(category="General", defaultValue="")]
            *  Specifies the text displayed by the Button control, including HTML markup that
            *  expresses the styles of that text.
            *  When you specify HTML text in this property, you can use the subset of HTML
            *  tags that is supported by the Flash TextField control.
            public function get htmlLabel():String
            return _htmlLabel;
            * @private
            public function set htmlLabel(value:String):void
            if (_htmlLabel != value)
              _htmlLabel = value;
              label = null;
               htmlLabelChanged = true;
               invalidateSize();
               invalidateDisplayList();
               dispatchEvent(new Event("htmlLabelChanged"));
            *  @private
            *  This label setter override for update toolTipSet property for this component
            override public function set toolTip(value:String):void
            super.toolTip = value;
            if (value)
              toolTipSet = true;
            else
              toolTipSet = false;
            *  @private
            private function get isHTML():Boolean
            return _htmlLabel != null;
            *  @private
            override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
              super.updateDisplayList(unscaledWidth,unscaledHeight);
            // If our width changed, reset the label text to get it to fit.
            if (isHTML &&
              (oldUnscaledWidth > unscaledWidth ||
               textField.htmlText != htmlLabel ||
               htmlLabelChanged||
               styleChangedFlag))
              textField.htmlText = _htmlLabel;
              var lineMetrics:TextLineMetrics= measureHTMLText(_htmlLabel);
              var truncated:Boolean = (lineMetrics.width + UITextField.TEXT_WIDTH_PADDING) > textField.width;
              if (!toolTipSet)
               if (truncated)
               super.toolTip = textField.text;
               else
               super.toolTip = null;
            oldUnscaledWidth = unscaledWidth;
            htmlLabelChanged = false;
            styleChangedFlag = false;
            *  @private
            *  This function overrited only for update styleChangedFlag
            override public function styleChanged(styleProp:String):void
            styleChangedFlag = true;
              super.styleChanged(styleProp);
            * This overrited function return TextLineMetrics based on htmlLabel property.
            * If htmlLabel is not null, its return TextLineMetrics for htmlLabel.
            * Otherwiset its return TextLineMetrics for label.
            override public function measureText(text:String):TextLineMetrics
            if(isHTML)
              return super.measureHTMLText(text);
            return super.measureText(text);
            You just code like below:
            <controls:HTMLButton>
                    <controls:htmlLabel>
            <![CDATA[ I am in <Font color="#FF0000">Red</Font>]]>
            </controls:htmlLabel>
            </controls:HTMLButton>
            These are the two attachments:
            HTMLButton1.zip
            HTMLButton.swf.zip
