0 Replies Latest reply on Mar 1, 2010 11:01 AM by smgilson
    [svn:fx-trunk] 14483: merge 14456: Adding ASDoc version tags classes
    smgilson Level 1
      Revision: 14483
      Revision: 14483
      Author:   smgilson@adobe.com
      Date:     2010-03-01 11:01:18 -0800 (Mon, 01 Mar 2010)
      Log Message:
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/automation/src/mx/automation/events/EventDetails.as
          flex/sdk/trunk/frameworks/projects/automation_air/src/mx/automation/air/AirDragManagerAut omationHandler.as
          flex/sdk/trunk/frameworks/projects/automation_air/src/mx/automation/air/AirFunctionsHelpe r.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkBorderContainerAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkButtonAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkButtonBarAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkButtonBarButtonAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkDataGroupAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkGroupAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkLabelAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkNavigatorContentAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkPanelAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkRadioButtonAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkSkinnableContainerAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkSpinnerAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkTabBarAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkTileGroupAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkTitleWindowAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkToggleButtonAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/SparkVideoPlayerAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/mediaClasses/SparkMuteButtonAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/supportClasses/SparkButtonBarBaseAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/supportClasses/SparkButtonBaseAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/supportClasses/SparkGroupBaseAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/supportClasses/SparkRangeAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/supportClasses/SparkSkinnableComponentAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/supportClasses/SparkSkinnableContainerBaseAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/supportClasses/SparkTextBaseAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/delegates/compon ents/supportClasses/SparkTrackBaseAutomationImpl.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/events/SparkList ItemSelectEvent.as
          flex/sdk/trunk/frameworks/projects/automation_spark/src/spark/automation/events/SparkValu eChangeAutomationEvent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/accessibility/AccConst.as
          flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/soap/SOAPResult.as
      Property Changed:
          flex/sdk/trunk/
