0 Replies Latest reply on Mar 1, 2010 11:50 AM by jmurphy67
    [svn:fx-4.x] 14484: backport trunk rev# 13964 to 4.x
    jmurphy67 Level 1
      Revision: 14484
      Revision: 14484
      Author:   jimurphy@adobe.com
      Date:     2010-03-01 11:50:39 -0800 (Mon, 01 Mar 2010)
      Log Message:
      Work around TLF bug #2545307.  ContainerController.mouseWheelHandler() should be checking if the default behavior is prevented before it acts on the event.  The workaround is to override TextContainerManager.mouseWheelHandler(), which dispatches to ContainerController.mouseWheelHandler(), and only call it if event.isDefaultPrevented() is false.
      QE notes: no
      Doc notes: no
      Bugs: SDK-25291, Watson #2545307
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration:
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25291
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/supportClasses/RichE ditableTextContainerManager.as
      Property Changed:
          flex/sdk/branches/4.x/build.xml
