2 Replies Latest reply on Mar 1, 2010 5:14 PM by mchi528
    Play Introduction Audio in Flash Catalyst
    mchi528 Level 1
      Can anyone show me how to use Flash Catalyst to play introductory audio when application first starts?
      Really appreciate the help in advance.
      Mike
        • 1. Re: Play Introduction Audio in Flash Catalyst
          Bear Travis Adobe Employee
          Hi Mike,
          To play an audio clip on application start:
          1. Import the clip via File -> Import ...
          2. Click one the Artboard (make sure no item is selected)
          3. In the interactions tab on the right, it should say "Application", and to the right you can click on "Add Interaction"
          4. Choose "On Application Start", "Play Action Sequence" and click OK.
          5. Click on the timelines panel in the bottom left (if it's hiding, double click the tab)
          6. Under Action Sequences, there should be an "On Application Start Item". Select it.
          7. Select any object in your first page (kind of wonky, but a sound effect needs a "target" object)
          8. Click on "Add Action" on the bottom of the Timeline, Choose "Sound Effect"
          9. Select the sound file you want to play
          It's a lot of steps, but it shouldn't be too complicated.
          -Bear
          • 2. Re: Play Introduction Audio in Flash Catalyst
            mchi528 Level 1
            Thanks, Bear,
            This works really well.
            Thanks again.
